Hi,
All my front vents have stopped blowing air. The rear vents, top of dash and windscreen vents are blowing air but not the vents towards your face. Anyone ever have a similar issue? Car only just turned 3 yrs old!
Fan not working
janahan9
Re: Fan not working
Wasn't working for 5 days after only doing short 15 min drives.Just done a 3hr drive , and tried it and it's now working fine. Did see somewhere that it could be due to low battery issues.
janahan9
Re: Fan not working
Tried it in the morning after being parked u for 15hrs- not working
Re: Fan not working
Try 'cycling' the air vent controls to force the air through different vents. It could be a sticky vent, or a fan.
Is the a/c working properly in terms of temperature?
janahan9
Re: Fan not working
Thanks for your reply. I understand what you mean - I hadn't thought of doing that. Will give it a go. Temperature wise, it seems fine.
Re: Fan not working
Can you cycle the a/c down to its lowest (16C) and up to max (30 something C) and see if it's OK at the 'extremes'. That will tell you whether you have enough gas or not.
janahan9
Re: Fan not working
The fan has now worked two days in a row, perfectly. Cycling through the temperatures also works. It's a mystery
