Head up Display
kamb
Head up Display
Post by kamb » Sat May 03, 2014 3:26 pm
Looking at installing head up display on car (just another gadget to add to my x5)
It has a red,black,and white wire
Does anybody know what OBD port numbers are power, ground, signal???
Or even how to wire it up?
petert
Re: Head up Display
Post by petert » Sat May 03, 2014 4:06 pm
This would be a very impressive retro fit - I hope you'll consider taking photos and notes and posting a 'How-to'...
Thanks!
Peter T
Re: Head up Display
Post by X5Sport » Sat May 03, 2014 4:31 pm
I take it this is an aftermarket HUD?
The OEM version runs on the MOST bus.
Power (+12v) - pin 16 - this is standard on OBD2 connections
Ground - pins 4&5 - also standard on OBD2 connections
Signal - 7 & 8 for the 'K' line.
There are lots of versions and a web search will help......hopefully.
Sanj
Re: Head up Display
Post by Sanj » Sat May 03, 2014 10:57 pm
This is for an E53? That's where this thread is posted. Would love to see this happen.
squeaky2
Re: Head up Display
Post by squeaky2 » Sun May 04, 2014 9:52 am
I was on the understanding that the windscreen is also different for HUD vehicles
Re: Head up Display
Post by X5Sport » Sun May 04, 2014 9:56 am
There are a number of them on Amazon, but none seem to be particularly good.
As noted above......One note of caution.  The current range of BMW cars which have a HUD fitted also have a special windscreen.  This is needed to ensure that the reflections from each layer of the glass in a laminated windscreen converge to form a single image.
These screens are fitted with a tapering core and are thicker at the bottom than at the top.  If you get the placement wrong you get a double reflection which can severely affect the image the driver sees.
The projector also uses a specially curved secondary mirror to correct the issues that arise from the curved glass of the screen too.
fenj66
Re: Head up Display
Post by fenj66 » Mon May 05, 2014 11:47 am
ive tried one of the free apps for my fone that makes a hud on the screen by placing it on top of the dashboard.  it only really tells you your speed via the gps. but at night id say it works really well.
Mpower
Re: Head up Display
Post by Mpower » Mon May 05, 2014 3:05 pm
I have the app on my iPhone and must say it's pretty good speed accuracy probably more reliable than the cars speedo,but as I already have HUD i tend not to use as much.
petert
Re: Head up Display
Post by petert » Mon May 05, 2014 7:12 pm
Ahhhh - so this post isn't about retrofitting a BMW HUD into a BMW X5, rather it's about installing one of the small after-market HUD devices that sits on the top of the dashboard.
Peter T
Re: Head up Display
Post by X5Sport » Mon May 05, 2014 7:39 pm
Well we think it is but the OP has gone silent.....
kjb1
Head up Display
Post by kjb1 » Mon May 05, 2014 7:52 pm
free HUD apps on the iphone work just as well as any of those units!! ( not as good as oem however obviously ).  Im having the m software coded onto my X5 soon for HUD! will give me revs etc which looks neater :)
Raj
Re: Head up Display
Post by Raj » Mon May 05, 2014 8:43 pm
Looked at these aftermarket hobbies. They come as a little kit with the screen clear sticker you need to put on the windscreen to make it work.
kamb
Re: Head up Display
Post by kamb » Sat May 17, 2014 11:27 pm
guys apologise been away
yes this was to fit an aftermarket HUD
having tested one of my friends you guys were right not worth the effort or the money
the display is very poor and inorder to reduce double reflection a iphone screen protector is required
all in all yes it looks the business in my friends car but the X5 no no as there is no where to conceal the projector
