F15 m sport front mudflaps
m13lky
Post by m13lky » Tue Apr 08, 2014 8:32 pm
Just fitted a pair of bmw front mudflaps to my white F15 m sport tonight, after 2 months I was getting sick of all the stones & grit that seem to find there way onto the front door steps & sills, also they will help for stopping some stone chips & tar, as usual bmw say they do not do mudflaps for m sport x5's but I got a set for 20" wheels from bmw direct on eBay & they fit perfectly, let me know if anyone wants the details.
Currently
F16 M sport 40d in space grey
Vw amarok edition auto in black
Previous
F15 M sport in carbon black
F15 M sport in white
Ford Focus Rs mk1
E70 lci M sport in space grey
F10 M sport auto in space grey
F10 M sport in white
E90 lci M spo
shadrack
Re: F15 m sport front mudflaps
Post by shadrack » Tue Apr 08, 2014 8:50 pm
pics pics pics
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Post by X5Sport » Tue Apr 08, 2014 10:01 pm
The big problem with Parts Depts is they often don't update their BMW system in good time and owners find out quicker.  It's not unusual for me to have gone into my local dealership to find that REALOEM is more up to date than they are.
Others just don't know their way around the systems due to the rather illogical places some of these parts get listed under!
allforus
Post by allforus » Wed Apr 09, 2014 9:13 pm
Can you let me have the details sure they will make a difference
X5 F15 30d msport
5 series g31 20d
Post by X5Sport » Wed Apr 09, 2014 9:26 pm
Straight from REALOEM - Mud Flaps.  Also see if your dealer will email you or print a copy of the EBA referred to.  It should be the fitting instructions.
Realoem's catalogue is 01/2014 so pretty up to date.  Next official release is either this month or June I think.
m13lky
Post by m13lky » Wed Apr 09, 2014 9:43 pm
[quote="allforus"]
Bmw Part number is B82.16.2.302.409 they will normally ask for your chassis number & then tell you they don't do them for m sport, this is the same for my last 4 bmw's all of which I have bought se mudflaps for that fitted perfectly to each m sport, I do not understand bmw logic on this, I got mine from eBay item number 171289126004, £75.50 delivered
Currently
Previous
Ford Focus Rs mk1
E90 lci M spo
Post by X5Sport » Thu Apr 10, 2014 11:08 am
Reading the part number on Realoem, that part number appears to be for cars with MSport trim as the non MSport ends .....402 according to the parts list.  Perhaps the dealers are getting themselves in a pickle as even BMW Direct 'appear' to have got it wrong too.
Which might explain why yours fitted perfectly?
m13lky
Post by m13lky » Thu Apr 10, 2014 1:45 pm
Richard, using the same logic after checking realoem would you say the rears that end in 431 should fit mine aswell?
Currently
Previous
Ford Focus Rs mk1
E90 lci M spo
Post by X5Sport » Thu Apr 10, 2014 3:34 pm
If you follow that logic then yes.  But if you read it the way it's written then 408 should be the right one and that's only for 18" wheels.... ???  No wonder Parts are getting confused :(
lucas0707
Post by lucas0707 » Mon Jan 05, 2015 6:31 pm
[quote="m13lky"]
Hi M13lky, i'M going to install the mudflap for my F15 M sport both front and rear, the dealer said about the front it's no problem, but the rear, they have to modified it. Do you have any ideas about that?
Mr bit
Post by Mr bit » Wed Apr 29, 2015 9:38 pm
just got my 1st x5 tonight and looking to install front mud flaps only, on a m sport has any one got any pics? And clarification on part no for the mud flaps that fit as my bmw dealer is also saying they do not fit m sport.
m13lky
Post by m13lky » Wed Apr 29, 2015 10:28 pm
I will email you pictures of my carbon black m sport with them fitted if you pm me your email address I cannot seem to get pictures to upload on here, I will also double check the part number above & confirm
Malc
Currently
Previous
Ford Focus Rs mk1
E90 lci M spo
Dr C
Post by Dr C » Mon May 11, 2015 2:49 pm
M13LKY, are they easy to fit, bearing in mind my unmitigated ineptitude with a spanner  :'(?
Current:
F15 X5 M50d
Mark 7 VW Golf GTD
m13lky
Post by m13lky » Tue May 12, 2015 6:39 pm
Dr c, yes all parts come in the kit, clean the front arches, turn steering full lock one way, drill out the centre pins of the arch fixings you need to remove, undo a screw underneath the sill part, just peel back the start of the body fixing double sided tape but make sure the end sticks out so you can remove the rest when it's in place, offer up mudflap to arch, fit arch fixings then screw back in at sill, screw self taper into last fixing hole on inside & into plastic arch liner then remove tape by pulling it from top down to sill & at the same time push the moulded part against the wing to stick it in place, remember & let the wings dry once you have cleaned them but don't polish it first or the tape doesn't stick. Takes about an hour to do fronts but longer to do rears as you need to remove the wheels.
Currently
Previous
Ford Focus Rs mk1
E90 lci M spo
Dr C
Post by Dr C » Wed May 13, 2015 10:32 am
[quote="m13lky"]
Thanks very much for this...unfortunately it looks like BMW direct have sold out. Will try to source elsewhere.
Current:
F15 X5 M50d
Mark 7 VW Golf GTD
