Sat nav problem
b20wht
Sat nav problem
Post by b20wht » Wed Mar 19, 2014 10:20 pm
My 2004 x5 sat nav has developed a problem. It was working fine but it now says it can't read the disc and sometimes no disc found! I have tried cleaning the disc and disconnecting the battery but its still the same.  Does the disc need updating or is it a problem with the drive itself?
2004 X5 3.0d
Re: Sat nav problem
Post by X5Sport » Wed Mar 19, 2014 10:33 pm
OEM disc?  If not, then that might be a source of the issue.
Could also be dust on the laser pickup head.
Mpower
Re: Sat nav problem
Post by Mpower » Wed Mar 19, 2014 10:41 pm
I find the non oem disc are very fussy on what type of media you are using,try it on another brand.
CondorX5
Re: Sat nav problem
Post by CondorX5 » Thu Mar 20, 2014 1:50 pm
Non oem discs can cause all manner of problems, try oem if you have not already done so. Otherwise there may be a problem with the laser - this can be repaired, there are a few people who offer online services - post it to them and they repair and send back. Or you can attempt the laser replacement yourself if handy with soldering iron.  Otherwise source a good used unit, get a mk4, and just replace the unit in the boot.
X5 2005 Le Mans Blue 4.8is
b20wht
Re: Sat nav problem
Post by b20wht » Thu Mar 20, 2014 10:33 pm
Ok thanks guys looks like I need to try and borrow a Orem disc 1st then.  My Dad has a 2007/8 Jag will that have the same disc as I believe they use or used a similar set up?
2004 X5 3.0d
b20wht
Re: Sat nav problem
Post by b20wht » Wed Mar 26, 2014 4:43 pm
New disc has fixed it
2004 X5 3.0d
