Television Not working
aneeque27
Post by aneeque27 » Wed Dec 25, 2013 11:47 am
Hi,
I recently bought X5 3.0D(2006) but the television is not working. I have tried rescanning all channels but still didn't worked. Although it shows all channels there but no audio and visuals. Can you please help. :(
thnx
Woofer
Re: Television Not working
Post by Woofer » Thu Dec 26, 2013 1:36 pm
I've the same issue, it is analogue and the system has switched to digital, you'll need to change the whole unit for aftermarket AFAIK
...or wait until u get home to watch TV  :)
F15 5.0msport
Post by X5Sport » Thu Dec 26, 2013 2:02 pm
Interesting.  A 2006 should have a dual unit as they were fitted from late 2004 onwards.  If you have an analogue only in yours then it's either been replaced with a different unit or that part of the receiver has failed.
All sounds a bit suspicious to me.
CondorX5
Post by CondorX5 » Fri Dec 27, 2013 11:49 am
As Richard said above, the TVs from 2004 onwards were hybrid receivers so both analogue and digital signals received......i had a late 2003 3.0i a few years back which was an early facelift and even it had a hybrid tv receiver, so either you are simply not in a good reception area or the original hybrid receiver from your car was swopped out by its previous owner.........
X5 2005 Le Mans Blue 4.8is
aneeque27
Post by aneeque27 » Sun Dec 29, 2013 4:10 pm
Sorry for late reply. Yes it does have a dual unit because when i rescan channels, it does say the Analouge channels found and digital channel found. But it could be that i m in a bad reception area.. Will try scanning some other place. cheers!
Sanj
Post by Sanj » Sun Dec 29, 2013 4:54 pm
Check the antenna is connected after that, both ends (at the unit end and in the windows - rear most quarter panels).
Drpellypo
Post by Drpellypo » Sun Dec 29, 2013 9:12 pm
Mine is 2004 and only appears to be analogue. How can you tell?
Post by X5Sport » Sun Dec 29, 2013 9:50 pm
Dual mode (hybrid) receivers were officially installed from production starting after 1st October 2004 - around Week 40 for that calendar year if memory serves.  If it was made before then then it is likely you won't have one unless the original unit was replaced under warranty.  After that date they should all be dual mode.
I think the TV module is down by the battery?  See if you can find a part number on yours.
Woofer
Post by Woofer » Sun Dec 29, 2013 11:24 pm
I'm now wondering whether I can get a dual mode OE replacement for my analogue receiver, any one got any clues as to where/how much?
F15 5.0msport
aneeque27
Post by aneeque27 » Mon Dec 30, 2013 10:11 am
hi,
Its working now, i think i was in a bad reception area.
Thanks for your help guys  :xmaswink:
Post by X5Sport » Mon Dec 30, 2013 10:50 am
[quote="Woofer"]
Should be a straight replacement.  Have a look on ebay etc.  Dealers can also supply, but the price is stupidly high - like several hundred pounds!!
If you do get one from ebay, make sure it is a proper dual mode unit and is for the UK TV spec (PAL/DVB-T) and not NTSC (US Spec).
Woofer
Post by Woofer » Mon Dec 30, 2013 11:30 am
[quote="Woofer"]
Cheers Richard, I'll go look  :)
F15 5.0msport
Drpellypo
Post by Drpellypo » Mon Dec 30, 2013 4:54 pm
Ah mine was March 2004. Bummer!
Drpellypo
Thanks for the info :)
Smeeagain
Post by Smeeagain » Fri Jan 10, 2014 5:13 pm
I have the September (!) 2004 analugie model - Id like to tackle this job but unsure as to the correct item - would someone mind posting what the correct item is on ebay as I ma unsure -  at my risk if I make the purchase etc
Smee
