I have a 2003 X5 and I have been unable to get the CD changer to recognize a burnt CD. When I put the CD magazine into the changer(with burnt CD's loaded) I hear the changer flick through all 6 CD's and the head unit displays 'No Discs'.
Has anyone been able to get their CD changer to recognize a burnt CD?
Can the CD changer play burnt CD's?
Current ride - 2003 X5 E53 Diesel Sport
Re: Can the CD changer play burnt CD's?
We know you Ozzie's like a BBQ but burning your cd's too
From memory i think the later E53's can play Mp3 cd's but these might have been from 2005-06 onwards.
Most guys either go for the Intravee or get the Aux socket fitted in the glovebox and use an mp3 player.
As long as the CD is a 'CD-R' then and burned as a normal Audio CD it should play, but certain brands of 'CD-RW' don't play as well as they should or at all.
If it's been burned as MP3 audio CD then as said above you need a CD changer from the late MY2005 onwards E53's.
Some CD burners seem to cause issues too. One of mine produced discs that were 100% OK and yet from another burner would not play except on a PC or home CD player. ???
- sramsay
Might also be worth checking if the discs are the original 650MB / 74 minute CD-R's and not the higher capacity ones.
I had tried TDK CD-80R 700mb 80min which didn't work. I'll try the lower capacity CD-R 650mb as you suggest. Cheers
I tried the TDK CD-80R 700mb 80min again and it worked fine but the difference being I had also put a commercial CD in the cartridge. The headunit detected the commercial CD and then i was able to choose the burnt CD.
Oh and I burnt the CD at 2 x speed.
Thanks for your help fellas
HI,
No Disk.............is a well documented issue.
It means your CD player is " Kaput ".
Been there, e-bay or friendly broker the cheapest options.
