Steering wheel shake
My steering wheel shakes like mad at mid speed
Help
0
No votes
Help
0
No votes
Total votes: 0
ozzyhufc
Post by ozzyhufc » Tue May 28, 2013 6:55 pm
Please help the steering wheel shakes like mad say mid speed ........what I mean by that is when driving slow all fine when braking and at 60plus ok braking until around 50-30 it shakes like mad ......what could it be.      If callipers or disc it would do it all the time surely
Re: Steering wheel shake
Post by X5Sport » Tue May 28, 2013 7:29 pm
Your vote has two 'Help' options.....
If it's not the brakes then it could be the bushes connecting the suspension, track control arms and suspension parts together.
It could just be a wheel out of balance or flat spotted or with a bulge.
Timoth27
Post by Timoth27 » Tue May 28, 2013 8:10 pm
What he said, first thing I would do is get the wheels checked/balanced as it could even be a buckled wheel. Did it start all of a sudden maybe after hitting a pothole perhaps. It's proberbly the cheapest place to start aswell.
Black e53 3.0d sport
shadrack
Post by shadrack » Tue May 28, 2013 9:17 pm
as above, wheel balance, wheel bearing, bottom arms either, knackered tyre, discs, sticking caliper...the list is endless, get it looked at or start looking :)
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Raj
Post by Raj » Wed May 29, 2013 12:10 am
As others have said it could be anything listed. I don't think it's the discs or tbh wheel balances. More common place is the bushes in the 2 lower arms connecting the chassis to hub. The front one is the thrust arm and rear the control arm. I replaced the front first but no better and then replaced the control ones and all sorted.
But as said you can try the simpler and cheaper options first.
Smeeagain
Post by Smeeagain » Wed May 29, 2013 12:57 am
I've had this for 3 years since I had the car. No one can find the issue - I've changed wheels (17 inch winters to summers - so different wheels and tyres), all wheels balanced. bushes all checked (and all passed 3 MOT's) no-one can find the issue and it doesn't seem to have gotten any worse in 3 years (which is another 75k miles.....you would think if it was some kind of wear issue it would get noticeably worse over 75k miles.
if anything my perception is that it happens less with the 17 inch wheels than the 19 inch but it still happens nevertheless.
Smee
Raj
Post by Raj » Wed May 29, 2013 8:31 am
[quote="smeeagain"]
Smee
The bushes appeared fine and passed MOT also. I changed the fronts due to searching and finding this was a common cause of the braking shake. I changed the rear control arms actually because noticed the balljoint protective rubber boot was a little perished and was causing a very slight knocking noise on full lock. And since changing the control arms all seems fine with the braking again.
jaynana
Post by jaynana » Sat Jun 01, 2013 1:02 am
i had this prob and it got sorted by changing teh front bushes.. of course the tyres got changed at the same time too.
i've seen that some others have got this changed by eventually changing the ball joints?
this is a common problem in the E53, all suspension parts are suspects, start with the lower cost items.
some go down the path of brake pads and disks which i think is the wrong way to go..
