Well i eventually took the plunge on Thursday and got the oil and filter changed in my gearbox and all i can say is "WOW" i really didn't think that it would make "THAT" much of a difference but i really can't put into words how happy i am, I am so happy i could sh!t in my hand and slap it on my head haha.
The gearbox was really smooth during the gear changes prior to the oil change or so i thought, no i can say it is virtually unnoticeable when she changes, the only complaint i had previously was sometimes when cruising up to a junction and then accelerating it was as though the gearbox didn't know what gear it wanted and usually ended up in a loud bang, a massive surge of power and a clap of thunder in my underpants. I have since tried to emulate the junction problem and it just won't do it anymore.
Well happy and at 330 quid (including enough oil for the next change in two months time) I really would say if your car has approx 80-90k on it then it is money well worth spent.
Craig
Holy gearbox oil change batman.
- Lummox
2004 54 plate 4.8is X5 E53 facelift in Carbonswarz-metalic.
Re: Holy gearbox oil change batman.
[quote="Lummox"]
Craig
You have to do it again in two months ? Presumably because it dislodges a load of crud? How much does the second visit cost ?
Smee
Craig
Smee
I think the 2nd, and sometimes 3rd change, is to ensure that all the old oil is out. You only get about 1/3rd out at each change because oil hides in the torque converter and other far off places inside the box.
05 Mercedes SL350
05 Mercedes SL350
- Lifer
Glad it's much better but how much are the 2nd and potentially 3rd changes going to cost?
- Lummox
Well the next one will just be the price of the filter and an hours labour as i already have the oil, so about 80 quid I would think.
- Lummox
I watched the mechanic do the job and he drained approx 4 to 4.5 litres of oil out and TIS says it is 9 - 10 litres for a dry fill. So really only half the oil has been changed. The torque converter is the problem as it doesn't drain when you remove the drain plug. A bit of a PITA but it has to be done.
Craig
Craig
- kena
Where did you get the oil from or was it provided by the mech. My 4.8 is going in for service on Friday and i'm also considering a gearbox oil change. I have 92k on mine now.
- Lummox
I got him to order it from bmw as he gets trade prices. If you are just getting it changed once I would recommend getting 6 litres to allow for flushing his pump and a little bit of spillage during the filling process.
