Webasto heater diesel info needed yes or no
gareth82
Hi I bought a 2001 3.0d X5 with 87000 miles two weeks ago. I have read a lot of different opinions on the webasto heater.
On my X5 MID display is says "vent on" only NOT aux heater. I have NO remote for the heater.
Can I purschase the £35 remote kit from maplin and fit. Does this give me the heat function?
Has anyone done this which I could chat with?
Any help greatly appreciated (dont want to waste hours reading forums and wast money and time if this cant be done)
thanks
thanks
2001 X5 3.0d sport
jonamv8
Re: Webasto heater diesel info needed yes or no
Mine had neither aux vent or aux heating as selectable options. BMW changed the aux heater today to fix it. I think you will need the aux heating option available to get it working.
I have the remote so not familiar with maplin fix but have heard others using it. Sure someone will fill in the blanks for you
- malc1950
Re: Webasto heater diesel info needed please
Hi i have a 2004 e53 sports diesel with a wabasto heater ,i fitted a telestart t91 remote which will turn on the heater motor but wont fire it up then
the motor turnes off after around 40sec or so , if i put a live feed to pin 1 "yellow and white wire",the heater runs and fires up warming up the car via the demister
vents , can anyone please help Malc950
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights, Rear view camera.
evoblue
Hello I have the £35 maplin remote with the timer built in. I had this connected / spliced into pin 1 on the webasto. worked perfect. The section "How to" has lots of information on it about this. It takes my car about 25 min to get warmed up. When I say warm, it is warm enough to clear the hard frost of the windscreen. My car is 05 3.0d sport. I now have the timers on the obc working so I have disconnected the remote.
Malc not to sure why yours is not working. The telestart module goes in the boot I think and links in. You have to rewire the front plug I beleive.
evoblue
- fenj66
gareth82 - before you spend time money in hopefully getting your aux heater to work when car parked up, a very simple test is to connect a wire from pin 1 of the multiplug on top of the webasto to the battery positive connector on the bulkhead behind the heater. keep the wire connected with engine switched off, the heater should start and run continually untill wire removed, say 30 mins so as to save your car battery.
if this all works ok then a maplin remote will do exactly the same job as youve just tested!
make sure the connection to pin 1 is a good one mind, its very fiddly to do, i used a scothlock connector.
good luck!
good luck!
- fenj66
Malc950. Your t91 system is probably having to accept the cars inbuilt criteria of air temp below 5deg C, 1/4 tank fuel, good battery voltage etc. Whereas hotwiring pin 1 prob bypasses this.
- malc1950
Hi evoblue how did you enable the aux heating on your OBC did you use a 1.4 scanner as i think i will try that next,
Malc1950
- malc1950
hi evoblue thanks for the link you sent me but i think the telestart t91 is coming off as i am not having much look with it ,
malc
- malc1950
Hi fenj66 thanks for the informatiom regarding my wabasto heater ,
but i think my next step is to get my OBC aux heating enabled like evoblue has before winter,
Malc1950
Sit
Bit off topic but when viewing facelift cars is there anyway of knowing if it has aux heater fitted and also are they fitted to both diesel and petrol cars?
Si
Si
2010 X5 30d M Sport Carbon Black | Camel Leather, 20's | HUD | Shadowline | Privacy | CIC iDrive | Adaptive Drive | Pro Nav | Loudspeaker Audio | High Beam Assist | Enhanced Bluetooth | Media Pack | Bum Warmers!
- malc1950
Hi Sit, you can tell if a facelift diesel has aux heating it will show on the OBC,
[quote=""Sit""]Bit off topic but when viewing facelift cars is there anyway of knowing if it has aux heater fitted and also are they fitted to both diesel and petrol cars?
Si[/quote]
Right hand side of the engine bay, big rectangular unit is the Webasto. Fitted as standard to the diesels. Aux heating is a factory option which you can add later. It is simply another function available from the Webasto unit.
Loads of info on this Board about enabling it and what bits you need. Either a Telestart Remote, or some bits from Maplin - cheaper and works as well.
Si[/quote]
Sit
Thanks for that, i am now focussing my search on V8 facelift models so i guess i don't need to worry about aux heating
Si
Si
evoblue
Hi Sit
I beleive that there was a few petrols with the heater added rare option. I think a couple of guys on here have them fitted. I expect again it will show up on OBC if it is. I am sure somebody will be able to tell you the location of the heater. So keep looking you might find one.
