635d (E63) map same as X5 (E70) 35d??
Pope
Post by Pope » Tue Feb 26, 2013 6:03 pm
Hi there  :help2:
Can anyone tell me if the OEM engine map in the 635d (E63) is the same as an X5 (E70) 35d map, and vice versa??
Could i swap maps between the two cars?
:pope:
Garage:
BMW X6 40d Pink
Ducati Diavel 1198 Carbon
Don Coffey
Re: 635d (E63) map same as X5 (E70) 35d??
Post by Don Coffey » Tue Feb 26, 2013 8:01 pm
Jason's your man for that question.  My own thoughts would be no, as I would suspect the ECUs are programmed to deliver two different program's due to the different jobs the cars are designed for.
Don
Sanj
Post by Sanj » Tue Feb 26, 2013 8:49 pm
NO!  :o
The maps are specific to each car! The ECU gets read - that file gets tweaked and then read back to the car.
The E63/70 maps will be different.
Jason will need to see the original file for each car and then map them separately.
Post by X5Sport » Tue Feb 26, 2013 9:14 pm
ECU maps will as said be different as the cars are different weights, have different performance, torque, power and emissions curves, they also have different gear and final drive ratios, and most importantly one is 2WD and the other is 4WD.  All of these will result in a lot of differences that need covering off in the ECU and how the ECU and Mechatronics Units in the gearbox converse.
Two different species of cars and not interchangeable.........
R
Sanj
Post by Sanj » Tue Feb 26, 2013 9:16 pm
Mechatronics[/quote]
Whatta great word!  :))
Post by X5Sport » Tue Feb 26, 2013 9:21 pm
That's its proper name - mechanical/electronics unit.  I bet it's even better in German.... :P
Pope
Post by Pope » Wed Feb 27, 2013 9:22 am
Thanx for the replies fellas. :thumbsup:
I kinda thought that the maps would be different, but there's no harm in asking eh.
:pope:
Garage:
BMW X6 40d Pink
jason@bwchiptune
Post by jason@bwchiptune » Thu Feb 28, 2013 9:09 am
Hi I see everyone has given you the correct answer
My best advice is to get your car remapped correctly by a well know tuner
Here is a dyno graph of one we did
We are based in London and have a dyno dynamics rolling road for power testing and tuning
Bwautorepairs
Bwchiptune
Unit 8-9 alpha ind est
clayton Rd
Hayes
middlesex
ub31bb
07831103030
02085611818
Last edited by jason@bwchiptune on Sun May 05, 2013 1:42 am, edited 1 time in total.
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
Pope
Post by Pope » Thu Feb 28, 2013 1:49 pm
[quote="jason@bwchiptune"]
Thanks for the reply.
I'm thinking of reinstalling the OEM in the 635d, as the massive torque is destroying my rear tyres. :(
So I'll have to get the mobile tuner that installed it to sort it.
I'm not thinking of remapping the X5 just yet, but when/if I do, I might give you a call.
:pope:
Garage:
BMW X6 40d Pink
Rusty
Post by Rusty » Thu Feb 28, 2013 11:30 pm
[quote="Pope"]
Reinstating the OE map? It's not the map that's the problem, it's your right foot.
As for the X, Jason is your man.  I'm sure that I am completely safe in saying that a map on the X will improve drivability (not saying they aren't good to start with, but things can always be improved upon) and you will most likely get better performance and economy too.
Jmho
Runabout - E92 3 Series Coupe
