Anyway.. If anyone knows, and can say would be grateful !
OEM / SatNav.. Speed based volume control / Hifi.
X5LeMans
Anyone know if Speed based volume is an optional extra, or if the setting is just hidden away somewhere? I had it on the E39, but haven't found how to set it on the X5. Probably somewhere really obvious
Re: OEM / SatNav.. Speed based volume control / Hifi.
Should be included. It is on all ours. The only way I could find to set it though was to change the volume when the Nav voice was 'speaking'. Even my Skodas had a function to set it properly!
X5LeMans
If anyone interested I tracked down the proper setting.
Turn on radio
Press Select for 8 seconds until radio enters service mode
Turn the control knob until option GAL is selected.
Options are 1 - 6 using preset buttons. Default on mine was 3. I prefer slightly lower so selected 2
Once set turn off radio to leave service mode.
Probably best not to set other options. I guess GAL is lost in translation from German
Found the info on the BSW website. It was for the BM53 radio module but worked just as well on my BM54
You can set the volume for Traffic Announcement as well in the same menu.
Turn on radio
