EML with Lpg conversion
lynxjock
Post by lynxjock » Wed Jan 23, 2013 6:49 pm
Anyone know how to turn off the EML with LPG fitted, EML has only been on since the conversion, if its an easy fix I will do it, otherwise will probably not bother, any help appreciated :-)
2013 BMW X6 40d, white with vermillion leather
shadrack
Re: EML with Lpg conversion
Post by shadrack » Wed Jan 23, 2013 7:06 pm
[quote="lynxjock"]
get your self the bmw 1.4.0 scanner for £20 and you can turn it off so will pay for itself the first time you use it and then you have it for all future use
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Post by X5Sport » Wed Jan 23, 2013 7:08 pm
......especially as it's now an MOT failure to have that light on.  Can't help with the answer, but surely it should not be tripped anyway?
lynxjock
Post by lynxjock » Wed Jan 23, 2013 7:44 pm
My mate works at main dealer and he said every LPG conversion he has seen has had the EML on, I think it's because the emissions are under the normal amount so the car thinks the lambda sensor is knackered. This car has been MOT'd with the light on and passed
Post by X5Sport » Wed Jan 23, 2013 8:23 pm
Looks like the EML light 'fail' has been deferred for 'further discussions with the Motor Industry'....probably because of what you and other LPG conversions have experienced which is not a fault as much as a 'feature' of the conversion.  Every day's a school day....... :)
ABS & SRS lights are in now though.
shadrack
Post by shadrack » Wed Jan 23, 2013 8:57 pm
[quote="lynxjock"]
my old x5 didnt have the light on with lpg, however it would maybe come on once every 3 months and go off on its own, i think your right though with your theory of why its on ;)
              2007 318d touring
              1964 vw beach buggy
lynxjock
Post by lynxjock » Wed Jan 23, 2013 11:12 pm
Tomorrow I'm off to a new Lpg installer to have the tank removed so I can sort the ICE out in the car, will have a chat with them to see if they have any thoughts or theories on it
Moh153
Post by Moh153 » Fri Jan 25, 2013 1:13 am
I have lpg fitted to my 4.6IS and my eml light came on once converted about a year ago and after the remap from the lpg company it hasnt come on again
IanP
Post by IanP » Fri Jan 25, 2013 10:21 am
I get the occasional EML with mine but it goes out pertty quickly so I am assuming its just finding a random missfire. Otherwise no problems on gas. I did chnge the O2 sensors recently but I believe thety should be done at about 80000 anyway....?
lynxjock
Post by lynxjock » Sat Jan 26, 2013 12:24 pm
Had the LPG tank out for a few days now to sort a new battery and full ICE replacement, EML not come on at all and have driven about 450 miles so far, the LPG installer who removed it for me has said he will try to sort it out when he puts it back in on Monday, seemingly a road test with the Laptop plugged into the system will hopefully sort it out :-)
Ubatoid
Post by Ubatoid » Sat Jan 26, 2013 6:11 pm
Your problems down to the LPG system. You will probably find that the reducer pressure is down so the engine ecu is compensating for the reduced pressure by increasing the injection period. It will only do this to a certain level before logging a "mixture adaption at  maximum" or similar fault.
Bottom line get the gas tuned.
2002 4.4 cooking on gas
Imy
Post by Imy » Sat Jan 26, 2013 8:06 pm
Strange, I've never had any lights appear whilst driving on lpg
robzilla
Post by robzilla » Sun Jan 27, 2013 5:01 pm
As long as the LPG is tuned correctly there shouldn't be any problems, the plugs need changing more often with lpg.
