Window Jam
Window Jam
Hi,
Ok new one, just looking for opinions...
My drivers window goes down but if opened all the way it gets jammed. now i can close it by sticking a screwdriver in the corner and the window comes up so it looks like its gotten dislodged or something.
do i need a new window regulator? or could it just be the clips?
Thanks in advance
PS iv had more problems in this car which iv had short of 6 months than 2yrs with a V6 alfa!!!
Thanks in advance
- Steamyrotter
Re: Window Jam
I Had this on the passenger side.
Mine was a broken clip securing the glass to the runner.
Modified mine with a penny washer and a bit of draught excluder!!
Works a treat now and is more supportive than the dodgy plastic bits...
Re: Window Jam
Nice one steamy. Il pull it apart and have a look this weekend. do you by any chance know the part number that needed replacing?
- Steamyrotter
Re: Window Jam
Item 7 on the inset picture of:-
http://realoem.com/bmw/showparts.do?mod ... g=51&fg=10
That is the bit that failed for me...
I modified a penny washer to fit between the glass and item 6
This then stopped the glass from popping off the bottom and twisting
Regards
Regards
Re: Window Jam
... Whats a penny washer?
- PhilUK
Re: Window Jam
Hi Imy,
I had the exact same problem with my front passenger window and it was the plastic window regulator clip that had broken.
Bought one from this ebay seller and it now works perfectly, still going strong 6 months on and only cost £7.50
http://www.ebay.co.uk/itm/BMW-X5-WINDOW-REGULATOR-CLIP-FRONT-RIGHT-/320963765951
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
Re: Window Jam
Cheers Phil,
just purchased it. was it an easy straight forward fix?
- PhilUK
Re: Window Jam
Fiddly but easy enough.
Thinking back I also replaced the two window retaining clips whilst I was in there as these are also know problem items which can cause the window to drop, mine where in bad shape too so glad I did.
Think I bought them directly from BMW for a couple of quid each. Part No: 51338254781
Here is a video on how to fit them which should guide you through fitting both parts.
http://www.xoutpost.com/bmw-sav-forums/x5-e53-forum/88838-diy-video-window-clip-replacement-tips.html
Here's how to get the door panel off in case you havnt done it before.
http://www.xoutpost.com/articles/x5/electronics-x5/9463-window-regulator-replacement-bmw-x5.html
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
Re: Window Jam
was it essential to remove everything within the door? i.e. padding, speakers, airbag etc?
- PhilUK
Re: Window Jam
Yes (except the speaker), you cant get the workings of the window otherwise.
It is easier than it looks to take it all off, I have now got it down to about 5 minutes.
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
Re: Window Jam
Yeah taking it off wont be a problem, iv done it many times myself. Its just i have limited access to the battery as iv got lpg, and im not sure if leaving the battery connected and then disconnecting the airbag etc will trigger any lights on my dash...
- PhilUK
Re: Window Jam
No need to disconnect the airbag, just take the fixing bolts out and tie it back out of the way still connected.
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
E53 X5 3.0d M-Sport
Sold
- Steamyrotter
Re: Window Jam
[quote="Imy"]
Basicaly a big washer with a small hole...
8mm hole but 25mm outer diameter..
