4.8is on a 3.0d?
4.8is on a 3.0d?
can i fit these on my 3.0d? will it still pass emmisions and everything?
Re: 4.8is on a 3.0d?
Fit what? Exhausts?
Probably yes, but you will need some welding done as the pipes are a different diameter. I think people have fitted the back boxes to these cars successfully with a bit of modification.
Emissions wise, as long as you keep as much of the original pipework as possible you should be fine. You need to maintain the right back pressure in the system, or have a remap done should there be any issues.
What you will notice is soot on the rear bumper. The 30d has no DPF which is why the exhausts point at the road. The later E70 versions come with DPFs as standard so exit to the rear.
- shadrack
[quote=""troy.wyse""]can i fit these on my 3.0d? will it still pass emmisions and everything?[/quote]
you can fit anything anywere if you try hard enough
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
[quote=""shadrack""]you can fit anything anywere if you try hard enough
Or use bodge tape..
Or use bodge tape..
- jason@bwchiptune
- Contact:
4.8is on a 3.0d?
You will need to wipe the soot of the back so don't buy a white car
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
