Boot!
LFP
Boot!
I'm looking at the boot of my E53 and why it doesn't seem to release cleanly when unlocked. The mechanism keeps whirring away, despite being unlocked and it needs lifting just a little bit by hand to stop it.
On the inside of the upper part of the boot lid, next to the protruding lock part there is a rubber cyclinder (called a bump stop?) approx 1 inch long. This is secured by a torx bolt. There is an identical bolt on the other side but no rubber cylinder. Is this the case on all models or am I missing one? This might explain the lack of required up movement to clear the mechanism.
I'm not referring to the two bump stops in the rain channel either side of the edge of the boot lid, in case my rambling explanation doesn't make sense.
I'd be grateful for input on this to stop me having to flag down a passing x5 and persuade the driver to let me look at his boot.
'04 3.0D Sport
dirtymonkey29
Boot!
1 each side, will double check when I get a minute. Have you had a look on www.realoem.com a website well worth bookmarking if you haven't come across it yet.
dirtymonkey29
Boot!
Should have part number, quantity required and a vague price. Is deffo 2 I've just checked mine
Denis O
Re: Boot!
There are definitely 2 bump stops. When I bought my car last year one of mine was mssing and one was broken so I replaced both. Quite shocked at the price though £10.74 + VAT each.
The part number is M51.24.7.141.879 and BMW call it a Buffer.
When the new ones went on the closing became quite stiff and you had to give it a bit of a push for the motor to catch and pull it closed. Still pretty much the same almost a year later.
05 Mercedes SL350
05 Mercedes SL350
- jaynana
Re: Boot!
[quote=""Denis O""]There are definitely 2 bump stops. When I bought my car last year one of mine was mssing and one was broken so I replaced both. Quite shocked at the price though £10.74 + VAT each.
When the new ones went on the closing became quite stiff and you had to give it a bit of a push for the motor to catch and pull it closed. Still pretty much the same almost a year later.[/quote]
also check this out mate, you may find some more info:
http://tis.spaghetticoder.org/e53/X5_4.8is_(N62_S)_OFFRD/Body_equipment/trunk_latch,_locks/
http://tis.spaghetticoder.org/s/view.pl?1/05/94/01
this is another great site (somebody in this forum pointed me to it) and it an answer most questions.
gchristofi
Re: Boot!
I've only got one of these rubbery bumpers / buffers on my car LHS... that would explain the recent annoying rattly boot.
I'm going to see if there's a DIY alternative to the daylight robbery of the stealers... probably not!
gchristofi
Re: Boot!
just to be clear, I'm talking about only having one of the rubber things right next to the tailgate latch, not the buffers in the outer sections as referenced in this link....
http://tis.spaghetticoder.org/s/view.pl?1/05/93/94
Re: Boot!
I posted about this very recently. To swap/replace these bump stops, it requires removal of a lot of interior trim on the D post as the buggers bolt in from inside
Another stupid bit of BMW design like a headlamp out to swap an indicator bulb
2009 35d, Space Grey with Chateau leather, just crept over 40k miles.
- Ubatoid
Re: Boot!
Check out my thread here - viewtopic.php?f=21&t=3016&p=32421&hilit=tailgate#p32421
2002 4.4 cooking on gas
gchristofi
Re: Boot!
think i need another of those then! Do you have the part no. handy? Was it from dealers? How much they fleecing us for??
LFP
Re: Boot!
http://realoem.com/bmw/showparts.do?mod ... g=41&fg=60
number 38 on the above link.
The part number on the package that mine came in was completely different. Might explain why its a different shape to the original. Cost about £10 (I think)
'04 3.0D Sport
phiggystardust
Re: Boot!
hi guys
sorry to jump on this but anyone know if these would have been fitted to a 2002 model that doesnt have the motorised catch ??would answer a lot if they are
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
