Cutting Out
Cutting Out
Post by henrym3 » Fri Feb 06, 2026 6:01 pm
X drives perfect then just cuts out, doesn’t matter what speed, idling along in traffic or 50mph. Will restart and run perfect again. Has happened about 4 times. Diagnostics does not show any faults. I have sent for a new ignition switch, Does this sound like a good idea or has anyone got a better one.
This is an edit :- passed the MOT yesterday without any issues.
Cutting Out
Post by X5Sport » Fri Feb 06, 2026 6:21 pm
IGN switch/wiring. Dodgy wiring around the injectors? As in a loose connector/cruddy pin? Loose earth? The only way to stop a diesel is cut the fuel/supply, so something causing that to drop on the electrical side.
I hate modern cars as the computer just shrugs it’s shoulders and takes the ‘nothing to do with me’ line :x
Good news about the MOT. :driving:
Cutting Out
Post by Leslie » Fri Feb 06, 2026 8:11 pm
Do a smooth running test on the injectors , mine showed injector 5 but injector 6 was also faulty but didn't show up as a code . It cutout as I was driving along too. :driving:
