Good morning all.
Anyone know what the back pressure means at 8192.0 with the car off? According to Gemini it means faulty wiring, it thinks it's the female pins which connect to the dpf sensor are not tight enough. I have checked the voltage which is 5v. Please see attached.
Back pressure
pcdee
Back pressure
Back pressure
Should be zero , faulty sensor or wiring I suspect.zit only had a regen 22 miles ago by the look of it.
Opps wrong conversion
pcdee
Back pressure
Thanks, I suppose the cheapest option is to buy a new dpf sensor and try that first.
Back pressure
I think I got that conversion wrong again lol
1hpa is 1mbar so sensor should be reading 0 with engine off.
Different units fry my head lol
Back pressure
Let us know if new sensor worked
