MOT
- henrym3
MOT
Got it done yesterday, as I have always had it mot’ed on gas I was for some reason apprehensive of getting the emissions done on petrol. No logical reason for the worry. Passed no problem apart from a minute movement in the wishbone ball joint which he pointed out but didn’t give advisory. Interestingly he didn’t pick it up on the wobble test but with a pry bar under the tyre.
MOT
Funnily enough my X6 now has ‘slight movement’ in the OSF lower ball joint. Not picked up at MOT but found during a routine ‘safety inspection’ at the same dealership. Glad you got through the MOT
Never anthropomorphise computers. They hate that.- Alan Gunn
MOT
All i can say is both me and my friend who owns the garage and doing the testing where very surprised.
He does a 2 man test so a second person does some pulling and shaking on the fronts plus a big pry bar if you understand.
- StuBeeDoo
MOT
There's no substitute for a decent tester's opinion. I had our spare Citroen tested last week and was absolutely gobsmacked when it passed. It had a knock in the front offside. "Shaker didn't pick-up anything, so I can't even advise it". I changed the bottom joint on Friday and by the look of it it should have failed. So much for safety.henrym3 wrote: Sat Nov 19, 2022 3:03 pmDoes that suggest that the wobble plate isn’t all its cracked up to be.
- Alan Gunn
MOT
Never seen Alun or The other tester James using the shaker.
They are old school like myself hands and pry-bar and always 2 on the job one in the car to do the bits like shake the steering side to side.
They are setup fot one man testing but never do.
- henrym3
MOT
If an examiner watched you doing an MOT would he not criticise you for not using the wobble facility. Weren’t they brought in to overcome bad testers. I do fully agree that there is very little substitute for experience.
