fuse 104 glow plug relay blown
ianmorris55
Post by ianmorris55 » Fri Jul 24, 2020 11:03 am
fuse 104 on the relay board in the glove compartment is blown, is this a relay fault
Re: fuse 104 glow plug relay blown
Post by X5Sport » Fri Jul 24, 2020 4:42 pm
Could be the control box yes. Glow plugs going short are unlikely to blow that fuse unless they all fail ‘short’ at once and most plugs fail ‘open circuit’. All mine did :cry: Worth checking the state of each plug. I think they should be about 1-2 Ohms if working correctly. High resistance or open circuit means a failure (as does a dead short).
