4.8is exhaust on a 4.4i
staffordcox
Post by staffordcox » Thu Aug 08, 2019 12:19 am
Evening chaps.
I’ve just picked myself up a pair of 4.8is exhausts (from centre box backwards) and found out that the pipes are different diameter sizes. I guess I should have posted on here before going charging in.
I’m sure plenty of you have done this to yours. How did you get them to fit? Did you buy the 4.8is centre section too? Or would I have the same problem further forward? Or do get them cut and welded about to get them to fit? Typically I’ve got my MOT on Friday and a knackered exhaust. I thought I’d be smart and upgrade at the same time. I should have known better really 😳
Can anyone shed any light please?
Thanks.
Re: 4.8is exhaust on a 4.4i
Post by Themoog2 » Thu Aug 08, 2019 2:48 pm
The 4.4 flanges need to cut off the old pipes as do the 4.8 flanges. Then the 4.4's have to welded to the 4.8 pipes with a small pipe extension welded in as 4.8's are shorter. If you see what I mean..
staffordcox
Post by staffordcox » Thu Aug 08, 2019 3:10 pm
I do, thank you. I’ll get on it.
Thanks for your reply 👍🏻
Post by henrym3 » Fri Aug 09, 2019 7:41 pm
Or just cut the flanges off and sleeve
staffordcox
Post by staffordcox » Fri Aug 09, 2019 8:15 pm
Off the exhausts or off the back of the centre section?
Post by henrym3 » Fri Aug 09, 2019 9:16 pm
Of the back of the centre section
