eventfull day :)
Ryoken
eventfull day :)
Post by Ryoken » Sun Sep 02, 2018 6:31 pm
I did the passengers side upper timing cover gasket , wasn't too much of a pita, couldn't finish it off as I couldn't find the rtv sealant
the valve gaskets at the top were like hard plastic, really brittle , bottom was a bit hard but not as bad,
brand new water pumo had a squeak on the  shaft, but when it was wet it went ,
only thing I have found it a slight lip of about 1mm between the cover and the block (cover being a tad higher) , and I cant get rid of it , new gasket should  compensate .
plus here's the pulley with the nick in it
2002 e53 4.4  tempremental
Re: eventfull day :)
Post by Alan Gunn » Sun Sep 02, 2018 7:22 pm
How did you get that nick in the pulley looks like a big bit missing.
Ryoken
Post by Ryoken » Sun Sep 02, 2018 7:55 pm
dunno , thing is I've not idea how long its been there
X5-D-Sport
Post by X5-D-Sport » Wed Sep 05, 2018 3:51 pm
I wouldnt worry too much about the pulley, the belt wont hop off.
I probably caught a small stone at some point in its life.
Post by henrym3 » Wed Sep 05, 2018 8:02 pm
I take it the chain guides filled you with confidence that they aren’t brittle and will break after you have sealed it all up? :)
Ryoken
Post by Ryoken » Thu Sep 06, 2018 3:34 am
not at all , there ok, them guides, the main thing im worried about is the 1mm lip between the front cover and the head :)
Post by henrym3 » Fri Sep 07, 2018 4:03 pm
Are you talking about the fact that the cover sits 1mm higher than the rest of the cam cover? I had this problem and set a flat piece of wood on the timing cover, loosen the bolts and use a lever to push the wood down till level. Then tighten a couple of bolts to keep it there. I had to use a piece of hefty rope tied to the chassis to give me the ability to apply pressure to the wood. Of course you will need to use your other pair of hands to achieve this or the Mrs.
Ryoken
Post by Ryoken » Fri Sep 07, 2018 7:08 pm
yeah, if you look at the cover and the block from the side or feel with your finger it looks like the front cover just sits too high, I thought ,  it was ok , and the rocker gasket or in fact the actual rocker cover would push it down, ( if I tightened down the rocker first then tightened down the front cover) ive got to take it all off again, because i didnt put any rtv on the bottom of the cover,
so, ill re do it tomorow, ill stick rtv on keep the cover loose,  then stick on the rocker then tighten up the front cover, and see how that goes
lezmtaylor
Post by lezmtaylor » Sat Sep 08, 2018 9:12 am
feeling a bit ignorant and ask the question : what is ''rtv'' ?
Lez
Ryoken
Post by Ryoken » Sat Sep 08, 2018 10:35 am
this :)
https://www.permatex.com/products/gaske ... t-maker-4/
you put rtv sealant in the corners and on certain parts of the rocker head
Post by X5Sport » Sat Sep 08, 2018 11:23 am
Room Temperature Vulanising compound - silicone sealant to you and me  :)
Ryoken
Post by Ryoken » Sat Sep 08, 2018 1:50 pm
that too :)
well I got rained off,  removed waterpump AGAIN . removed front cover,  re  aligned it properly , with the aid of a large screwdriver,  applied sealant of appropriate bits, then totally destroyed the waterpump gasket getting it back on , I HATE the coolant pipes. whilst getting wet.
so today, all ive done , is been at the same point
got to wait for another dry day to finish it off
Post by henrym3 » Sat Sep 08, 2018 1:55 pm
Haven’t you got an umbrella, sounds to me like a poor excuse for a day off :)
Ryoken
Post by Ryoken » Sat Sep 08, 2018 2:06 pm
I didn't really fancy getting wet through ,
ironically I have a garage :).  but cant get into it , as there is a 330 coupe in front of it , and the garage is full of tools on the floor , and bits of a m62 engine top :)
lezmtaylor
Post by lezmtaylor » Sun Sep 09, 2018 9:27 am
Thanks a lot, 75 and still learning !!
Lez
