Hey all,
I am a sucker for having a car with loads of bells and whistles and finidng one with all of them is proving to be a challenge, so i olan to buy one with most of what i want and retrofit the rest (i quite enjoy this)
The key thing’s id like to do below are:
1 - surround view on a pre-lci
2 - corner cameras
3 - rear heated seats
4 - rear blinds
5 - individual audio
4 & 5 i know how to do but 1-3 im stuck with, anyone tried/done these?
X70 retrofits
Re: X70 retrofits
Have a look at Realoem, use the last 7 of your VIN in serial number, and check what kits are available.
If they aren’t offered by BMW then it’s a case of searching part by part
The E70 onwards are not easy to upgrade and retrofit - though not impossible - due to the way the electronics are locked via licence and serial numbers recorded in the iDrive/computers.
Never anthropomorphise computers. They hate that.- snrbrtsn
Re: X70 retrofits
I’d be inclined to revisit your list of must haves, consider adding HBA & Adaptive Xenons as priority
I know of the perfectly specced car with 4 out 5 + the above, sadly its a five seater....
SIN6H
Re: X70 retrofits
Could you send me the details? I could always look into adding the thrid row?
Re: X70 retrofits
Beware of doing that as it changes the type certification and towing & payload weight limits for the car. If you add seats to a 5-seater you will need to get it re approved. Certain things are not permitted on 7-seater cars that are on 5-seaters. There are subtle but key differences in the body shell construction.
Buy a 7-seater.
Buy a 7-seater.
SIN6H
Re: X70 retrofits
Wow, never knew that! Thanks for the heads up
libra007
Re: X70 retrofits
well self leveling suspension and run flats with no spare tyres are there for a reason. its not a straight conversion at all.
2009 X5 MSport
graemeX5
Re: X70 retrofits
[quote="SIN6H"]
Hey all,
2 - corner cameras
4 - rear blinds
Hi as others have said it's tricky to retro firi bits on the E70.
It may be worth waiting for the better spec car, items 1 and 5 are common but items 2 and 3 are less so and retro fitting item 3 a forum member was quoted over 2k for heated rear seats.
Re item 4 the rear blinds I've only seen a couple of times as most will tint the rear windows instead.
You may find that the SE model cars may have a better spec over the MSport ones.
Graeme
Hey all,
2 - corner cameras
4 - rear blinds
Graeme
