Rear parking sensor removal
themoog
Post by themoog » Wed May 30, 2018 10:13 am
I have two new rear pdc sensors to fit on the near side. I can reach them from underneath but how do they come out? Chuffing things are well wedged..
Re: Rear parking sensor removal
Post by Alan Gunn » Wed May 30, 2018 12:19 pm
Post by marti » Wed May 30, 2018 4:47 pm
Theyre just tight....normally two clips one each side of the sensor you have to  pinch in...
https://www.newtis.info/tisv2/a/en/e53- ... dc/CDyOWVn
ttr
Post by ttr » Wed May 30, 2018 9:14 pm
Themoog
Eh up I have just done mine, the little beggars are tight in.
I did this:-
Used my plastic pry set
Undid exhaust blanks
From the outside inserted my pry tools gently on the edge of the outer sensor cover
Moved it on the edge down toward the bottom
As the gap increased slid the other pry tool in the other side and did same
I found my outer cover then popped out from the bottom
Once the outer was off you can then easily push the sensor and inner housing out through the exhaust port
Then clean it up and slide the sensor out and Un clip the electric cable
It’s a bugger refitting too, I did the reverse once I figured out how stuff clipped together
No way could I figure out how it could be done any other way.
Hope this helps
BMW X5 E53 3.0D Auto Sport 2006
themoog
Post by themoog » Wed May 30, 2018 10:06 pm
Thanks for that. What are the exhaust blanks? Do you mean the bits on the bumper that surround the tailpipes?
Post by Alan Gunn » Thu May 31, 2018 5:46 am
[quote="themoog"]
yes
