New Battery
X5Andym
New Battery
Post by X5Andym » Sun May 20, 2018 10:00 am
Hi All..
I need to buy a new battery for my E53 2005 4.4 (X5), so many on the market..  :( can any one recommend the best one available, have a bout 150.00 to spend..
Andy  :)
Re: New Battery
Post by Alan Gunn » Sun May 20, 2018 10:57 am
Some members have fitted this one including me.
You can get one today in Halfords but not at this price.
https://www.ebay.co.uk/itm/Yuasa-Car-Ba ... 1438.l2649
V8 00USH
Re: New Battery
Post by V8 00USH » Sun May 20, 2018 12:24 pm
If you can push to it get an AGM battery - especially if you car isn't used very often. One of the best things I've bought for mine.
Re: New Battery
Post by X5Sport » Sun May 20, 2018 3:03 pm
AGM = Absorbed Glass Mat (in case you wondered).
Some E53s got them by default (my 2005 30d did) and most modern cars use them.
X5Andym
Re: New Battery
Post by X5Andym » Sun May 20, 2018 7:00 pm
Thank you.. got a Yuasa as advised.. currently fitted.. but have had starting problems.. turn the key all light up,, but does not start.. may happen four to six times.. then starts up..  >:( any ideas.. please.. bad earth..
Help please (only 37,000 on the clock...)
Thank you..
Andy
Re: New Battery
Post by marti » Sun May 20, 2018 7:04 pm
Possibly your ignition switch....if its like the e38 7series its not where the key goes in, its a black box connected to the back of the barrel, so you have to drop the lower steering column trim/panel to get to it...easy to change.
Re: New Battery
Post by henrym3 » Sun May 20, 2018 7:19 pm
Do the lights go out or dim when you try to crank and then return bright when you release the key?
