Run Flats
X5M50d
Run Flats
Post by X5M50d » Sun Nov 19, 2017 5:19 pm
Am I right in saying run flats are non repairable resulting in having to purchase a new replacement tyre. I have Pirellis with a screw in the drivers side front with only 7k miles on it :'(
Re: Run Flats
Post by Alan Gunn » Sun Nov 19, 2017 5:32 pm
That is repairable only when it's side wall damage is it a buy new job.
Some places will say no so shop around it can be fixed.
Re: Run Flats
Post by Horizon » Sun Nov 19, 2017 5:40 pm
Members on here have had Runflats repaired, certain companies/ dealers won't repair them.
The reason is I guess is that if you have had a puncture and run on it with no pressure in for 70 miles ( as is the whole idea of Runflats ) the tyre will have sustained sidewall damage and need replacing.
If the light comes on due to a 5 psi drop in pressure due to a slow puncture, no damage will have occurred.
So that tyre will be safely repaired.
It's where you draw that line.
I cracked an alloy on the E93 and drove on a runfat with no pressure in it for 50 miles to get to a place that rewelded it, the tyre was knackered internally and the amount of rubber inside the wheel when it was removed was very noticeable.
I replaced them with non Runflats ( no star marking problems as 2 wheel drive )
Re: Run Flats
Post by X5Sport » Sun Nov 19, 2017 6:17 pm
My local place repaired one of mine with a few less miles on it but a 1/4 bolt in the middle.  He said the tyre manufacturers say they can’t be fixed but plenty of places ignore that.  I only did a couple of miles on it and it was finally replaced when it wore out  :D
MarkG_M3CP
Re: Run Flats
Post by MarkG_M3CP » Sun Nov 19, 2017 6:55 pm
eTyres will repair them so long as they haven't 'run flat'. £25 and completed on your drive.
Current: F80 M3 Competition Package and F20 M135i
Gone: F15 X5 M50d / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
X5M50d
Re: Run Flats
Post by X5M50d » Sun Nov 19, 2017 9:25 pm
Thanks everyone, that is reassuring to hear.
I do have tyre insurance and after speaking to them about it they had said non repairable on their part - hence my question to you all.
As I can only claim 5 times over 3 years with the policy I really didn't want to use my first claim on a repair only job.
Cheers ;)
kenniff
Re: Run Flats
Post by kenniff » Mon Nov 20, 2017 10:49 am
I had a slow puncture at c 1000 miles. No running on it when flat as the TPMS alerted me to the issue. Kwik Fit said their policy was not to repair - but the mechanic (who shall remain nameless) took me aside and said he would do it "off the books".
In the end I opted to replace the tyre anyway.
Abbot26
Re: Run Flats
Post by Abbot26 » Mon Nov 20, 2017 3:41 pm
There’s loads of repaired runflats on eBay, I think tyre garages tell us they can’t be fixed, sell us new ones then fix them once they’ve rinsed us
silverbeemersurfer
Re: V, W and Y rated Run Flats
Post by silverbeemersurfer » Mon Nov 20, 2017 6:38 pm
The key points regarding the possibility of a repair being carried out on V, W, or Y rated tyres have previously been mentioned.
The position and size of the penetration are paramount. Repairs should not exceed 6mm in diameter. The penetration must be between the two shoulder areas, definitely NOT within the shoulder areas. Depending on the actual tread pattern, as a guide the shoulder area is normally considered the area extending from the first main groove in the main tread pattern outwards over the shoulder. Only one repair per tyre should be allowed.
The tyre MUST be removed and physically examined by a fully qualified technician for internal structural damage before a decision is made regarding a possible repair.
Combi-Plug repairs should only be used after the tyre has been de-mounted and checked, on no account should this type of repair be used without examination of the interior.
Finally, check manufacturers websites for guidance if you are not sure. Generally, subject to the above guidelines, these tyres can be repaired.
These are guidelines for UK/Europe countries. For more information I suggest a visit to somewhere like the Rema Tip Top website.
