Gearbox / Transfer box issues.?
Nine468
Post by Nine468 » Sat Mar 18, 2017 7:09 pm
After reading about the gearbox/transfer box failings on the E70,s of late, [2011 ish dates] im just wondering what the symptoms of a failing box are.?
What does a bad box feel like when its on its way out.?
Cheers ....
Dave W.
BMW G05 X5 40D
martin33100
Re: Gearbox / Transfer box issues.?
Post by martin33100 » Sat Mar 18, 2017 7:27 pm
Slightly off topic but now I have BMW ISTA D software I have found out our 08 E70 has the fault code for worn transfer case oil (comes up as VTG oil wear), my C110 scanner didn't show it.
I hope to change the oil tomorrow and then you can select you have changed the oil on ISTA.
Post by X5Sport » Sat Mar 18, 2017 7:49 pm
Symptoms are normally jerky drive on full lock or odd rumbling noises from the front/rear diffs and or transfer box.
