Air Con Pump replacement...
X5-D-Sport
Post by X5-D-Sport » Fri Mar 10, 2017 9:32 pm
Just a little question...
E53 D-Sport 218....
Can the AC pump be removed/replaced from under the vehicle, or is it only removable from above after stripping the exhaust manifold & turbo out of the way 1st ??
Are the gaskets available on their own ? or can some gasket sealant be used instead ?
Any one done this job ?
Re: Air Con Pump replacement...
Post by X5Sport » Sat Mar 11, 2017 10:20 am
Realoem shows separate gaskets with their own part numbers (in the engine subsection) so you should be able to get them as individual items.  Might be main Dealer only though  :(
Can't help with removal options though.
X5-D-Sport
Post by X5-D-Sport » Tue Mar 21, 2017 11:45 am
Many thanks
