Rear wiper stopped wiping.
Dave ett
Half way through a journey the rear wiper stopped wiping. Luckily it is parked is the right place. The washer still works.
Any clues where to look first?
Thanks in advance.
Thanks in advance.
Onlinehenrym3
Re: Rear wiper stopped wiping.
fuse
[quote="henrym3"]
fuse
Motors have been known to go, relays/ relay bad connection. Switch.
Find out which relay it is , check signal voltage at relay / or if relay is clicking/ operating , when the stork is activated, check voltage at wiper motor, if you have voltage at the motor and it still doesn't work. Probably motor is toast. As said first point of call is the fuse.. good luck
fuse
Dave ett
Thanks guys!
themoog
Another thing to check is where the spindle passes through the glass. Mine was stopping/ going slow until I removed the end seal and put some WD40 in it.
strummer
[quote="themoog"]
ditto!
ditto!
- Steamyrotter
[quote="Horizon"]
[quote="henrym3"]
fuse
[quote="henrym3"]
fuse
Dave ett
To follow up now I've fixed it...
Along the lines of the post above:
No problems with supply to unit and washer pump still worked, so figured it was an issue within the unit.
Removed it and dismantled, to find a build up of crud around the bushes / motor commutator. A squirt of cleaner and polish up sorted the problem for free.
Bushes are very low so I expect it to fail again at some point. Will begin a search for replacements.
Don't spend money replacing things you can fix within an hour with nothing more specialised that a torx bit!
Onlinehenrym3
Interesting subject, looks like a job for some day I'm bored and put it down as preventive maintenance. Well done for fixing it and letting us know
Dave ett
Out of interest, it is an identical unit in the L322 Range Rover - complete with BMW logo...
