Good morning XDrivers fans. I am wanting to by myself a egr bypass for my e53 3.0d but looking on good old Ebay i have found two diffrent ones so would just like to know your input for getting the right one. Here are the two links to the ones i have seen
http://www.ebay.co.uk/itm/BMW-E39-E46-5 ... SwofxUlyZx
http://www.ebay.co.uk/itm/BMW-E39-5-Ser ... SwLF1X3pQd
e53 3.0d egr bypass
- powers1
Re: e53 3.0d egr bypass
If you want a top quality kit ,call LLoyd Allard on (0)1452 725 666,mentioned Fernando(me) and he will do you a good price better than advertised.Here is their website ,appropriatelly called EGR VALVE
http://egrvalve.co.uk/index.php?route=p ... ath=66_112
He is an excellent welder and been doing his kits ,including intercooler kits ,for +20 years ,
2003 model E53-3.0D.55k, Full extras,mods ,including "facelift" grills and modded DEPO headlights
Hi Rory,
The link of yours below copied is the one I used.
It blanks off the EGR pipe from the manifold so you can totally dispose of this pipe, AND the electrically operated valve.
The Small 5mm vacuum pipe is simply blanked off by folding the pipe & securing with a zip tie... & the electrical connection is just tied out of the way....
When you do the job, place a small rag UNDER the EGR unit, as the Torx bolts will drop under the engine other wise... the rag catches them..
Total time to do the job... about 30 mins.
The engine breathes a little better, & give a tinsy bit more torques & maybe a mile or two better economy.
It is also worth getting a K&N air filter, as this does add a few HP to the performance.
Grant B
Grant B
