Dpf stats review
john_o
Dpf stats review
Post by john_o » Wed Aug 24, 2016 10:35 pm
Hi,
I have an x40d and read the dpf values today.
Can someone help with what they mean, expected values etc?
Thanks john
alan996
Re: Dpf stats review
Post by alan996 » Thu Aug 25, 2016 10:54 am
Plus one to that...
My 07 3.0d is showing 32g ash mass and according to Carly it has never requested a regen
I have no idea what the safe values are
Sent from my Nexus 6P using Tapatalk
Post by X5Sport » Thu Aug 25, 2016 6:01 pm
Soot is the unprocessed stuff that a DPF regen needs to get rid of next time it runs.
Ash is what is left after the regen and ideally you need to know the %capacity that is.  Once over 55% of capacity then the DPF needs a specialist clean to get the ash out.
The regen figure from the 07 looks like it has probably done one recently and is running fine.  If that figure rises and nothing happens then that is when you start checking.  It should run every 300 miles or so.
The figure for the 40d could be 6 miles or 6,000 miles.  If the latter then that needs looking at, but if it's 6 miles then it should happen somewhere around 300 miles as long as the car is fully warmed up and doing at least 40mph for twenty minutes.
The usual clue it is running a regen is that all the engine fans keep running for up to 15 mins when you switch off.  It's to stop the (plastic) front wings catching fire from the extreme heat the DPF is producing (700-800°C).
john_o
Post by john_o » Thu Aug 25, 2016 8:09 pm
Brill thanks x5 sport.  I do hope it's 6 miles! Wonder what capacity the x5 dpf is?
Thanks john
Sent from my SM-N910F using Tapatalk
Post by X5Sport » Thu Aug 25, 2016 10:33 pm
In normal motoring you should not expect a DPF to get full and need replacing at less than 90k miles.  Short journeys are the killers as the system doesn't get hot enough so the regen won't run and it clogs up.  A replacement is the wrong side of £1,500!
Marrow
Post by Marrow » Fri Aug 26, 2016 1:07 pm
How do I get this Carly thing ?
I have seen the app in the App Store so obviously that but which is cheapest / best adapter for I phone 6 ?
Lci 3.0d e70
Link would be good if you have one
Post by X5Sport » Fri Aug 26, 2016 1:45 pm
Just look at mycarly.com
It's all in there.  You need their Gen 2 adapter to make use of the current updates.  The adapter is anywhere from £30-50 depending on where you look (Amazon for example have it for £40) and the App is whatever it currently is on the App Store.
You need the full (paid) version.  I have not seen any other make of adapter so assume you must buy theirs.
john_o
Post by john_o » Fri Aug 26, 2016 10:21 pm
Here it is a few days later 10g up on the soot and up 1 on the regen counter.
Wierd
Wipeout
Post by Wipeout » Mon Aug 29, 2016 9:45 pm
John O, the regeneration requested box details what mode of regen is being carried out.
On my 07, once the soot hits a certain level, usually above 40grams, it goes from 0 to 1 detailing that it's ready for a regen, once other parameters are met, once this happened it goes to 4 and the regeneration starts, you can then see the soot drop back down to 0 and the regeneration requested box goes from 4 to 0. There was a list somewhere online that detailed what the various codes meant.
john_o
Post by john_o » Tue Aug 30, 2016 7:56 pm
Thanks wipeout.  I will have a dig. Here's how it looked later on and some other details from icarly
Wipeout
Post by Wipeout » Tue Aug 30, 2016 8:35 pm
That looks like it's in the middle of a regen, the soot has dropped, as soon as it gets to zero or close you will see the distance traveled since regen reset to zero and the  regen requested go from 4.00 back to 0.00.
PhilT
Post by PhilT » Sat Sep 10, 2016 3:08 pm
John_o, how did you get to display that last more detailed set of parameters? I've got the Carly stuff but can't seem to find anything more than the basic 4 parameters for DPF?
Phil
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
john_o
Post by john_o » Sat Sep 10, 2016 7:08 pm
Cockpit > parameter page.
Mine seemed defaulted to dpf data but you can select anything to log.
