Any one on here that sort my key out
Just got back from hols cars was sat for 16 days battery went dead now key won't start it,can open the car with the buttons but won't start.
But starts fine with the spare any ideas
Help needed in South Wales if pos could drive to you then
Diamond key re programing in Wales ?
- Sanj
- Lifer
Re: Diamond key re programing in Wales ?
Charge the battery up first, then start the car with the dead key and let it charge the car on a LONG run (could be low voltage and it has a 9v rechargeable battery in it that charges through the key barrel).
If that doesn't work try a re-programme (have a search on here). Think your battery is playin up but try the above first.
Sorry should of said new battery fitted and the key still won't start the car but will open it and all the buttons work will work as need just won't turn the car over
- Sanj
- Lifer
Re-programme the bugger then - quick search duder.
