X5M e70 engine malfunction reduce power
x5mkal
Post by x5mkal » Mon Aug 15, 2016 11:37 pm
Hi guys
I was running low on fuel and had the engine malfunction come on, had it checked by my friends snap on diagnostic and it through loads of fault codes, help needed as don't no where to start I've been told
It's hpfp
Kal
Re: X5M e70 engine malfunction reduce power
Post by X5Sport » Tue Aug 16, 2016 9:58 am
Could be a single injector, plug or coil pack would be my guess as it doesn't say multi-cylinder issues.  Worth checking the fuel filter too in case it needs replacement and is crudded up?
x5mkal
Post by x5mkal » Sun Aug 21, 2016 1:00 am
Thanks for the reply
Imy
Post by Imy » Sun Aug 21, 2016 7:46 am
Have you tired clearing the codes and seeing if they come back in the first instance?
x5mkal
Post by x5mkal » Sun Aug 21, 2016 5:06 pm
Yes cleared all codes, but 2B2A still showing also I've just noticed my engine fan is running countisouly on start up, checked the AC and its switched off
Kal
Imy
Post by Imy » Mon Aug 22, 2016 2:00 pm
your code reader says 2b2a is fuel pressure related?
Shouldnt that be Idling speed control valve initialisation?
I think your issue may be linked to throttle actuators?
x5mkal
Post by x5mkal » Tue Aug 30, 2016 5:42 pm
Got it booked with the dealers, time for a big bill  :(
mogsyman
Post by mogsyman » Tue Aug 30, 2016 6:36 pm
I had some minor parking damage repaired to my F10 M5 and whilst it didn't have much fuel in when I dropped it off it had bugger all in when I picked it up  >:D
I ran out of fuel ¾'s mike from the Coachworks which didn't go down very well!
Cut a long story short the car took half an hour to get going again and threw up exactly the same faults as you have however once it had a good flow of fuel it was all back to normal. I think at one point I was deep in the brown smelly stuff but it seemed to sort itself out.
Has the car run since you filled it up?
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
x5mkal
Post by x5mkal » Sun Sep 04, 2016 9:31 pm
Yes the car starts and drive but has no power, think the fuel pump or hpfp needs doing
x5mkal
Post by x5mkal » Wed Sep 07, 2016 5:11 pm
All fixed guys by myself, hpfp bank 1 replaced running like new again
