Retro fit head up display x5 e70
Elec cert
Hi looking for a bit of advice, I am going to be fitting a head up display to my lci e70.
I have the hud, wiring loom, hud switch, light sensor and NCS expert to do the coding.
Need pointing in the right direction as regards to coding and any help would be appreciated.
I know the hud needs to be added to the VO does any one know what else would need coding
Many thanks
Gary
Many thanks
Gary
Re: Retro fit head up display x5 e70
Have a search on bmwcoders dot co dot uk. I don't know of anyone on this forum that has added it.
Have you also got the correct windscreen? It's a special one for the HUD otherwise you will get double reflections. The correct one has a special laminate profile (thicker at the bottom) and is triangular if cut in cross section vertically. You won't get the reflections from each glass layer to coincide without it.
Elec cert
Hi thanks will have a check, I will be getting the windscreen fitted once hud up and running
celica
I have this option and love it
Also nice with the nav display on it too
Out of curiosity, are the dash blanked when not factory fitted so can uncover and add or will you need a new dash?
Elec cert
Hi yes definitely a must have option have had on a previous x5...
Will be cutting hole in the dash and fit trim piece but will need to remove dash to do it
litany
NCS expert, use expert mode profile, add option $610 to VO, write in CAS and FRM, code whole car as will be easier for you.
diluxe
Seems like a lot of work for what is a very basic HUD display, the information and colour palette is very limited.
The f'series hud is much more comprehensive and visually better.
- Waka
Saw one of these when I went to the dealers the other day:
http://f30.bimmerpost.com/forums/showth ... ?t=1063158
looks good for (I think) about £450.
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
graemeX5
I think that's pretty good for the money and has more info than on my HUD current unit fitted to the car. And if You swop between those models you can take it with you for the next car.
Graeme
Graeme
