Heater plugs??
Baker3570
Heater plugs??
Post by Baker3570 » Thu Apr 07, 2016 7:34 pm
Hi all, so since buying the X5 couple weeks ago I've been hit with a few problems but battled through most of them and sorted...
But... I noticed yesterday after work (10 hours) the car struggled to start turned over a couple times then fired up, did a trip to the shop on way home and it started fine.
This morning really struggled to start and then same again after being stood 10hours.
Once started chucked out abit of white smoke but then soon cleared
Could this be the heater plugs? And can these be tested via being put on a computer?
Thanks in advanced
fenj66
Re: Heater plugs??
Post by fenj66 » Thu Apr 07, 2016 8:04 pm
Brief white smoke on cold start up would indicate glow plug failure. But car should spin over fast anyway. Poor starting speed might be a bad battery.
Baker3570
Re: Heater plugs??
Post by Baker3570 » Thu Apr 07, 2016 10:48 pm
Is there any specific way of testing the glow plugs?
Baker3570
Re: Heater plugs??
Post by Baker3570 » Fri Apr 08, 2016 6:34 am
Oh well could very well be battery too came to it this morning turned over a couple times then stop then again then click click click
Nice long walk to work for me  :(
porku
Re: Heater plugs??
Post by porku » Fri Apr 08, 2016 1:36 pm
[quote="Baker3570"]
Not realy, easyest way with computer, beacause when you want to test them with multimeter than you need to take off intake collector beacause there is no room to check them any other way.
PS! When computer says that all of them are dead, then you have probaly issue with Glow Plug relay.
Baker3570
Re: Heater plugs??
Post by Baker3570 » Fri Apr 08, 2016 8:27 pm
Thanks for the reply, well green flag came out to it and jumped it off there boost pack and fired up straight away. He said there doesn't seem to be a problem with th glow plugs as it didn't try and struggle to start.
He thinks it's just a bad battery that needs replacing
But now since this I drove it for about 5 miles then the self level susp inactive has now showing on the dash
grumpywurzel
Re: Heater plugs??
Post by grumpywurzel » Fri Apr 08, 2016 8:33 pm
A low battery voltage will cause other errors, get the battery tested. Sounds like it's on its last legs
2005 X5 3.0d Sport
Re: Heater plugs??
Post by X5Sport » Fri Apr 08, 2016 9:27 pm
And one other possible, you will need a current clamp to check it, is the starter motor.  It is a known weakness if a Magnetti Marelli starter is fitted.  It should draw 180A but can be much higher.  My E53 one failed and drew over 900A - more than the battery could deliver, and I changed our E46 one in the summer, it was drawing 540A.
Battery is very likely, but the clue for the starter is it cranks slowly - such as a bad battery would - even when the battery is fully charged.  It could kill a fully charged battery in about three starting cycles!
It is a diy job, if a bit fiddly, as it isn't the easiest thing to get at.  Replacements are available from ECP for under £220 including the surcharge which should give you about £100 back.  I put a new Bosch into the E46 and the difference was immediate.  Fast cranking, near instant start.  :)
Worth keeping in the back of your mind if there is no issue with the plugs or battery.  It won't throw any kind of error code.
Baker3570
Re: Heater plugs??
Post by Baker3570 » Fri Apr 08, 2016 11:26 pm
Thanks for that, I'm going to go and have the battery tested before paying out for a new one. And work my way through stuff :)
Baker3570
Re: Heater plugs??
Post by Baker3570 » Sun Apr 10, 2016 11:06 am
Haven't had time to have the battery tested yet due to work but it has been cranking fine and starting up till this morning where it was a little colder than the other days.. Took abit of cranking (lazy) then fired up but with a big puff of white smoke took the little lad to rugby can out cranked over quick and fired up instantly
Hopefully getting it booked in for Tuesday to be checked out
TimX5
Re: Heater plugs??
Post by TimX5 » Sun Apr 10, 2016 12:02 pm
[quote="Baker3570"]
Sounds like battery is on its way out
