Gear leaver won't move into manual mode
E46ACS
Post by E46ACS » Tue Mar 29, 2016 1:43 pm
Hi, not mine, but a friends. '08 3.0sd.
Was all working fine, now, in auto mode all ok, but the gear leaver will physically not move over to the left to select manual mode.
Near leaver? or worse?
Nine468
Re: Gear leaver won't move into manual mode
Post by Nine468 » Tue Mar 29, 2016 3:13 pm
Thats spooky, as mine has started doing this..
A sharp tap to the left and i found it releases. But i cant keep doing this , im guessing something is sticking...
I dont want to go spraying WD40 around it though as it might upset something... ::) ::)
Anybody any ideas.??
Dave W.
BMW G05 X5 40D
celica
Post by celica » Tue Mar 29, 2016 8:46 pm
I suspect the lever is at fault
Lever itself is about £800 as a part I believe
Nine468, does yours spring back to park from sport mode when you press P?
E46ACS
Post by E46ACS » Wed Mar 30, 2016 10:30 am
Thanks. thought as much.
Post by X5Sport » Wed Mar 30, 2016 7:22 pm
Sounds suspiciously like the joystick unit is on the way out, and it can only be replaced as a unit.  BMW want obscene amount of money, but you may be able to find on line somewhat cheaper.
Realoem will give you the right part number to look for - if it goes that far.
E46ACS
Post by E46ACS » Thu Mar 31, 2016 3:33 pm
Thanks  :thumbsup:
Nine468
Post by Nine468 » Mon Apr 04, 2016 10:49 am
[quote="celica"]
Mmmm, not tried that yet. i just put it back into D before i park up...
UPDATE... Yes it does spring back from sport when P is pressed....
Dave W.
BMW G05 X5 40D
