Just purchased a 2013 x5, as I use the car to tow my caravan im Wanting a spare wheel kit or do I rely on the run flats
Thanks ste
Wanted e70 spare wheel kit
Steve p
Re: Wanted e70 spare wheel kit
A tricky one that. Although towing on a skinny spare is not illegal, BMW are adamant that it not be used when towing - according to a similar recent question on the Caravan Club. If it was a rear RFT that failed you may find that the tyre simply would not cope with the load when flat for more than a very short distance, meaning you would have to abandon your 'van' whilst waiting 2 days to get a replacement tyre. You can't even swap front to rear as the sizes are different!
Manufacturers really didn't think it through when going to skinny spares or RFTs. The E53 wasn't so bad as the spare was a full size 17" wheel, sadly not the case with later versions.
You might just have to carry a can of goo whilst casting around for someone nearby with an RFT.
Steve p
Thanks for the quick reply , I'm traveling to the south of France in the summer I will purchase a couple of tubs of the sealant just in case
Thanks ste
Thanks ste
Gulkolx5
Hi Team
On subject of GOO Is the Holts universally used or do some use other types? The BMW tyre inflation kit seems expensive to me and not sure if it would be effective on the runflats. Would it be better to change to non runflats or is there no difference putting GOO in to either tyre type?
sid10
Depending if it is an E70 or a F15 they did a winter set of wheels that were all offset Et48 they were all run on 255/50/19 tyres and as a none staggered set fit both front and rear . As they are the standard tyres and not a space saver no problems with towing . pm me for styles that fit ?
http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-GB
Or if you want a wider wheel, may not fit under the boot carpet
sid10
That should be fine as it is has an et48 offset , it won't fit an X5M though !
