AC Pusher Fan - an age old problem here I think !!
X5-D-Sport
Post by X5-D-Sport » Thu Dec 31, 2015 5:31 pm
E53 Diesel Sport - 2004.
AC pusher fan has never worked....
Replaced the fan  - still does not work.
Another member "Ryoken" has a similar fan issue too...
Power is getting to the two big cables & the black is hooked to the earth OK...
the signal wire is buried away in the loom & is undamaged...
I retro fitted an El-Cheapo e-bay unit last summer, which helped in preventing me getting boiled alive in a few traffic jams, but its ugly & I'd sooner have the original fan working properly..
Any suggestions ( :))poliite ones :)) ) ?
Ryoken
Re: AC Pusher Fan - an age old problem here I think !!
Post by Ryoken » Fri Jan 01, 2016 9:59 am
get your ac recharged, mine was empty . that's why the ac was cooking me ,  that fan is there just for HOT countries
if you get ac charged and it cools down , forget the pusher fan
2002 e53 4.4  tempremental
Post by X5Sport » Fri Jan 01, 2016 10:10 am
The fan is used here in the UK too.  He's already had the system regassed.
X5-D-Sport
Post by X5-D-Sport » Fri Jan 01, 2016 12:39 pm
The AC works perfectly as a system... just gotta keep the vehicle moving.
but just cannot get the air thru the condenser .. ie.. the fan is knackered & will not turn.
The gas pressure is fine.
so, repeating the question...  how can I get the fan to work ?
Post by Horizon » Fri Jan 01, 2016 1:49 pm
I have read that INPA can be used to test / cycle the fan on all variable speeds, the trigger wire as you call it is operated by the DME module. Seems INPA May help to determine if it's a faulty wiring or module
X5-D-Sport
Post by X5-D-Sport » Fri Jan 01, 2016 1:52 pm
INPA.... not heard of this before.. sounds interesting.
how can I get the fan to cycle ?
what is the procedure ... at least this may help nail the fault ?
Post by X5Sport » Fri Jan 01, 2016 3:48 pm
INPA Edibias is the official BMW software.  The full dealer version is on their GT1 system - or whatever it is now called.  You will need to set it up on a laptop.  It is available on line.  :)
Probably the best source of all the files is BMWCoders dot com.  It will allow you to look as all the car functions, test a number (or all) of them and make coding changes too.
You need the main program and then the correct data files for your car type, plus an interface cable between the laptop and car.
ScottBarton
Post by ScottBarton » Mon Jan 04, 2016 1:18 pm
I have exactly the same issue on my 2004....will be keen to learn any resolutions.
Same symptoms...fine when car is moving, AC lovely and cold. When stuck in traffic and stationary...not very cold at all.
I have never seen or heard the pusher fan kick in.
Current:
2017 M50D
2016 Porsche Cayman 981 GTS
Past:
1990 1.9 205 GTI Miami Blue (Sold 2014)
1994 MR2 Turbo T-Bar, 397BHP with NOS (Sold 2021)
2004 3.0D X5 Sport Rest in pieces 2021
TimX5
Post by TimX5 » Mon Jan 04, 2016 6:58 pm
Try unplugging the sensor under the bonnet on the osf  air con hose
X5-D-Sport
Post by X5-D-Sport » Tue Jan 05, 2016 10:05 am
Heard about this sensor - located it also -
what does it do & how can it be tested as working or not ?
I've also ordered a pack of software & cable to interrogate the vehicle systems & fault diagnosis, hoping it will arrive this week too..
Ryoken
Post by Ryoken » Wed Jan 06, 2016 9:49 am
y more info or distructions on using inpa to  test the fan , I have inpa, but never been able to find the fan "control"
and I'm too interested in this sensor on the ac hose
Micevo
Post by Micevo » Fri Jan 08, 2016 5:52 pm
Also try unplugging the temp sensor bottom left on rad hose that should bring fan on,
X5-D-Sport
Post by X5-D-Sport » Fri Jan 08, 2016 6:05 pm
Done that... doesnt make any difference...
however.... the replacement fan I got off Flea-bay some time ago... may also have been faulty...
nice1guv
Post by nice1guv » Mon Jan 11, 2016 5:33 am
Not sure about INPA, but with BMW DIS you can activate the fan.
Under control unit functions, then DDE, there is an activate fan function.
Best to check the fuses behind the glovebox as well, I believe one of the big 50Amp red ones is for the fan.
Steamyrotter
Post by Steamyrotter » Mon Jan 11, 2016 1:12 pm
XDSS.
I am assuming you have checked voltages on all connections??
Confirm you have 12v at the power leads
Then see what you are getting from the control core
You should see something on there, even if it is a pulsed signal.
That would discount wiring.
If i remember i'll have a poke around on mine at the weekend and see what should be seen from a (surprisingly) working one...
I believe INPA can activate fan, but need to confirm as never tried it for that part....
Going down the DIS route will give you many a headache.........  :-[
