Battery 2008 E70 3.0d
E53Steve
Post by E53Steve » Thu Oct 15, 2015 11:01 pm
Ok, Battery discharge or something similar displayed on idrive this morning, car started but noticed a bit slower turning over, late finishing work so only place open was Halfords for another battery so bought one from there with view to fitting when I came home but thought i'd better to a search to make sure it is straight forward, but after searching here and other sites it looks like it need coded/paired to car, although the BMtroubleu on youtube doesn't mention this and chap at Halfords didn't mention this (although doesn't surprise me) so standard BMW battery still fitted but on the way out 12v 90Ah 900A, bought the Yuasa 12V 100Ah 900A thinking a little more power which should benefit, does this have to be recoded? I presume so as it is not like for like. Anybody done this and not coded and had problems? I know it has been mentioned before but just needed some advice, i would suspect the battery has been changed on a few of the E70 X5 now and not all by BMW or people with relevant software.
your help much appreciated
Re: Battery 2008 E70 3.0d
Post by X5Sport » Fri Oct 16, 2015 4:38 pm
Yes you need to 'pair' the battery so the systems know it's a new one, what 'type' it is (as in AGM, Calcium, Wet) and it's rating (Ah).  Bosch Silver batteries are a better bet.
If you don't paint it then the charging system will continue to think you have the original battery and either under or overcharge it.
I'm not surprised about Halfrauds......they can only just about handle the tech in a Mk1 Astra, and even then it's only if they can read a Haynes manual (which will require all of them to be able to handle long words).  An E70 is a whole library of knowledge beyond that!
E53Steve
Post by E53Steve » Fri Oct 16, 2015 8:52 pm
Thanks for the info, was starting to wonder if it was for Start/stop cars as I presume they would have quite a strong battery due to having to start the car every 5min
Post by X5Sport » Sat Oct 17, 2015 3:07 pm
The E70/71 draw up to 60A off the battery with the engine off!
gmc15
Post by gmc15 » Sat Oct 17, 2015 3:32 pm
Does a new battery have to be paired by a dealer or indy or is it something that you can do yourself?
x6 M50d
Post by X5Sport » Sat Oct 17, 2015 4:05 pm
I think you need software to do it so an Indy with the right kit.....or even a member on here.....should be able to do it.
It only takes a few mins to do.  I haven't tried the Carly App, but owners of that may have found the option.....
kjb1
Post by kjb1 » Sat Oct 17, 2015 6:59 pm
I have used icarly app to code new battery on e70.
Sent from my iPhone
E53Steve
Post by E53Steve » Fri Nov 13, 2015 9:13 pm
Well changed battery myself and all OK once car got moving again after the normal 4x4 failure etc all due to battery being disconnected, no big deal, I went in to my local Bmw dealer and explained to them, they told me that the battery needs to be registered to the car, which is now done. Don't know whatbenefit that does but done now
Post by X5Sport » Fri Nov 13, 2015 10:18 pm
It resets the intelligent charging system so it knows about a new battery and changes the charging cycle to match.
E53Steve
Post by E53Steve » Mon Nov 16, 2015 10:41 pm
Thanks for the info X5sport. much appreciated.
