Wheel change
allforus
Wheel change
Post by allforus » Thu Oct 01, 2015 10:47 pm
Just put a set of wheels I bought early this year on to the car so gone from 20 inch staggered to 18 inch same what a difference so quiet and compliant
Going to run them until next spring I think
X5 F15 30d msport
5 series g31 20d
Turks
Re: Wheel change
Post by Turks » Fri Oct 02, 2015 3:36 am
I presume this is for Winter Tyres? Did you make sure the rolling radius was the same?
Turks.
Present:
Past:
allforus
Re: Wheel change
Post by allforus » Fri Oct 02, 2015 7:22 am
The wheels where off the f15 SE so no issues there although not winter tyres  thought it would save the wheels from the winter weather and make the tyres last until next summer
X5 F15 30d msport
5 series g31 20d
sid10
Re: Wheel change
Post by sid10 » Fri Oct 02, 2015 8:45 am
Hi not sure if they are the correct offset as usually the M sport has a lower offset on the rear et18-21 , Se is et45-53 . I would ask a main dealer as it could effect the cars stability .
allforus
Re: Wheel change
Post by allforus » Fri Oct 02, 2015 3:35 pm
Yes they are the wrong offset but know different to the se they are all still f15 same axle etc I understand the handling will be affected
But I don't drive it hard
X5 F15 30d msport
5 series g31 20d
GD
Re: Wheel change
Post by GD » Sat Oct 03, 2015 10:40 am
I had to change my rear tyres last week at 22k, my fronts are fine and am holding off for my replacement wheels.  There was still 2mm on the rear and I had wanted to wait until next month when I was going to get winter wheels and tyres.  I am a tight git and don't fancy giving BMW £2500 for winter wheels (I have the 20 inch) but saw on mrwinterwheels does a set of 18inch alloys with tyres from £807. The cheapest tyres, not RF are well rated in Canada and those with a puncture kit will suffice.
As I say, I am tight but also quite clueless when it comes to wheels and a friend has to get a new diff (I'm sure that's what he said) on his Mitsubishi thing when he put the wrong wheels on.  Will the 18inch with winter tyres be fine if not what am I looking for?
X5 3.0D MSport (F15)
Z4 2.0 MSport (e89)
VW Golf VI 1.6 TDi Bluemotion
DrDel
Re: Wheel change
Post by DrDel » Sat Oct 03, 2015 5:49 pm
Bear in mind some insurers treat changing wheels as a modification, they don't often charge more, but will want to know if you've fitted winter rubber
Re: Wheel change
Post by X5Sport » Sat Oct 03, 2015 6:33 pm
Winter rubber no longer an issue for the majority of companies.  There was a 'concern' 5 years or so ago, but not these days.  I don't even need to tell mine.
AW8
Re: Wheel change
Post by AW8 » Sun Oct 04, 2015 6:05 am
Agreed Peter but as indicated  the issue was a bit of a stumbling block a few years ago with a few companies. Maybe worth being mindful of &/or checking with insurer as best to know before a claim rather than after one is rejected following an assessor being thorough.
Winter rims are one thing but different specs and offsets could be an issue.
Re: Wheel change
Post by Horizon » Sun Oct 04, 2015 9:33 am
[quote="AW8"]
+1
I changed my wheels on my Golf from 17''s to 18" and AXA charged me extra, as it was classed as a modification.
I've just  ditched the Runflats on my 3 series, and my insurance is due next week for renewal, Swiftcover is coming out the cheapest on a comparison site, so I will find out if they are bothered about it before I pull the trigger.
Turks
Re: Wheel change
Post by Turks » Sun Oct 04, 2015 9:52 am
I don't ever recall being asked what wheels (size or model) were on any of my BMW's so for me, having an alternative set of OEM Wheels is not something I'm going to waste 20 minutes on the phone to my insurers for. It would be different if they were Aftermarket.
Turks.
Present:
Past:
DrDel
Re: Wheel change
Post by DrDel » Sun Oct 04, 2015 5:20 pm
^^^^ Tis your decision Turks but the small print says its your responsibility to let them know if there is any change to the car's spec. Some companies are even looking to load premiums when 'factory' options are dealer fit !!
Since the cost of repairs keep rising they will look harder and harder for any issue to get off the hook. If your were unlucky to face a sizeable claim that's exactly when they'd be checking the small print- personally I'd take the 20 minutes.
chris.t
Re: Wheel change
Post by chris.t » Sun Oct 04, 2015 5:58 pm
I would give the insurance company a buzz they might not be bothered, but could save a lot of hassle if you had to claim for what ever reason
Present 2016 Audi S8
Previous 2014 BMW 640d msport
Previous 2012 BMW X5 30d msport
Re: Wheel change
Post by X5Sport » Sun Oct 04, 2015 6:01 pm
And some companies charge you just because you phone them!  You can't win with these rogues! >:(
Mine (John Lewis) don't care as long as everything is OEM.  If it isn't then they count it as a mod.  Mine is under the BMW Extended Warranty so everything I use is OEM - to stop BMW pulling a stunt like those mentioned above. :(
GD
Re: Wheel change
Post by GD » Tue Oct 20, 2015 2:03 pm
[quote="GD"]
Thanks for all the info on insurance, they have no issue, so does anyone know the answer to my question about the wheel and tyre size?
Z4 2.0 MSport (e89)
