Here is an odd one..misfire?
themoog
Post by themoog » Mon Sep 21, 2015 1:29 pm
Ive bought another E53 4.4 2001 and have only had it a week. It was cheap so i expected a few things to sort. It has a fsh
Anyway, I am not sure if it has a bit of a misfire so ideas please.
If i drive it steadily in any gear at about 1500-2000 rpm the engine seems to cut out / hesitate for a fraction of a second every minute or so. The rpm drops about 50-100rpm but then goes back up to what it was before. Its so quick it's barely noticable.  I tried to replicate it on the drive but it didnt do it. Only when actually driving the car.
There are no codes stored and it starts / idles ok. Fuel consumption is ok.
On the odd occasion when gently accelerating, again at between 1500/2000rpm, the car shudders for a few seconds. If I accelerate a bit harder it will not do it.
Can the plug coils fail on a certain load/ engine speed?  Could it be fuel related?
Any ides are welcome. Thanks
themoog
Re: Here is an odd one..misfire?
Post by themoog » Wed Sep 23, 2015 10:36 pm
Nobody got any suggestions? I'll have to get a diagnostic done I think..
themoog
Post by themoog » Fri Oct 09, 2015 7:30 pm
Ive been diagnosing it myself.. I think it may be transmission/torque convertor trouble. Every now and then i get a judder circa 1500rpm @ about 30-40mph. I dont think the TC is locking up (not sure if it is supposed to) in top gear when cruising at about 50-60mph. I think it's momentarily jumping out of drive but only for a fraction of a second which feels like a misfire. It only does it when up to temp so could poss be trans fluid/pressure related.
If anyone has experience or ideas please feel free to post.
I want to fix this as the rest of the car is really good (apart from drivers door mirror-grrr) and i dont like giving up.
Post by X5Sport » Sat Oct 10, 2015 9:40 am
If you have access to diagnostic kit it should be possible to get a transmission code read.  I had no warning lights with mine but the fault code showed 2 clutch packs and a brake pack failure.  In my case it was a TC failure that triggered the disaster (it all happened in seconds with no pre warning).
Yes the lock up clutch should work.
themoog
Post by themoog » Sat Oct 10, 2015 3:55 pm
Hmm. I'll put my C110 on it tomorrow to see what's there. I may just do a fluid and filter change anyway. £150 and a few hrs under the car may just be worth it...
