Is brake sensor required for brake pad changes?
Is brake sensor for the pads or discs, as I need to change pads?
Re: Is brake sensor required for brake pad changes?
I did mine as a service item when I changed the pads all round. They aren't expensive. If it hasn't been triggered then it should be fine to re-use. I chose to change as they were 9 years old.
As you said
Not expensive so might as well
