Digital Television
- Sherwood
Digital Television
Does anyone know if the Television in the X5 can easily be converted to Digital?
I guess we are all going to have to make the change when they turn off analogue?
BMW E53 2003 X5 3.0D
phill
Digital Television
Easiest way is to put the BMW digital tuner in, but it is around £600 I think. The cheapest is to buy a freeview box and a cable that allows you to connect to the original analogue tuner and use the AV channel on the screen.
Sent from my iPod touch using Tapatalk
2003 SAAB 9-3t convertible 175bhp - current
2003 X5 4.6is - Now dead
Timh
Re: Digital Television
It depends on the year of the x5. The newer ones 2004 ish and newer have digital tv modules fitted. I believe it's easy to change the module....its the one on the right hand side by the battery. The problem is that the upgraded module is not cheap. It would be cheaper to wire in a separate digital tv tuner into the existing analogue tuner using an av lead. You wouldn't be able to use the sat nav screen to change channel but they do come with a remote control and an eye you could mount somewhere upfront in the car. You would then use the av function on the nav screen to see the picture.I believe the genuine BMW module is about £1k new! Even on eBay they go for around £500!
Tim
Tim
- x555
Didgital tv modules were September 2004 onwards ......mine is an august build
and our analogue was turned off eons ago.
- jeegnesh
Digital Television
May have one of these for sale in a month or two. Can't believe the price
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
- bullethead
[quote=""sherwood""]Does anyone know if the Television in the X5 can easily be converted to Digital?
Cheers[/quote]
I made the change and yes it's really easy but just ain't worth the money. Exscuse my language but it's shit
Cheers[/quote]
Pete
[quote=""x555""]Didgital tv modules were September 2004 onwards ......mine is an august build
and our analogue was turned off eons ago.[/quote]
I'm sure mine was built in Sep 04 or afterwards. You've got me wondering if mine has a digital module that just needs re-tuning.
- bullethead
Spoke to an engineer working on the switch over who said that even in areas which have already switched over it will take a couple more years for all the little transmitters to be upgraded. Here at home cracking digital reception even with a tabletop aerial. In the car i've got to go up on the downs to get a pic, went down to New Forest last summer and brilliant picture even on the move after jas enabled it. Well as far as Salisbury then naff all.
- CondorX5
If you have a good signal, the digital picture is great. Unfortunately, this can mean just a few yards can make a massive difference in reception, unlike analogue signals, which may get a bit fuzzy, but are more tolerant in weaker reception areas. Digital : no fuzzy pictures, its either there ot its not....or you get the severe picture breakup as in very bad weather / storms high in the atmosphere. I'm glad my X has a digital tuner, but I'm not sure about spending £600+ on the OEM tuner, there are much more worthwhile buys.....I'd be tempted to go the digibox route with a magic eye and view TV via the AV input - you can do that for well under £100, but its a bit more effort to get it neatly installed.
X5 2005 Le Mans Blue 4.8is
[quote=""Pete""][quote=""x555""]Didgital tv modules were September 2004 onwards ......mine is an august build
I'm sure mine was built in Sep 04 or afterwards. You've got me wondering if mine has a digital module that just needs re-tuning.[/quote]
Have a look under the bonnet. Your build month and year should be in there. Black label, can't remember which side though. Try a retune and see what comes up.
phill
Digital Television
Think it's the drivers side for date manufactured
Phill
Phill
petert
My E53 was a sept 04 build and was analogue.
Peter T
Peter T
- x555
[quote=""phill""]Think it's the drivers side for date manufactured
Phill
Sent from my iPod touch using Tapatalk[/quote]
Was it a Septemder build ??? check the sticker under the bonnet on the drivers side wing.........if it is then sorry for the duff info
but i was told on the old forum that the change over was Sept o4.
EDIT: Sorry post was meant to be for pete....it's been a long afternoon
Phill
petert
I believe it was but I've sold it now to another forum member (Pete) who might check and confirm.
Peter T
Peter T
sturach
Hi all
Ive got freeview on my 2006 X5
And as said the picture is good when you get a good signal (this is very rare and having to rescan quite often when in different areas)
Do you think when the analogue signal is completely turned off the digital signal will be boosted
so the cars with freeview will get a better signal strength
thnaks in advance
thnaks in advance
