Parking brake failure
pcdee
Post by pcdee » Wed Jun 24, 2015 6:52 pm
Hello all
As the title says.
Had her out of a service which included glow plugs, glow plug controller, egr thermostat and oil change.
Probably not related but after a couple of days I pulled up and pressed the park button and 'bing' the warning appears in yellow.
I can clear the fault and used the handbrake but every so often it will come back.
X5 E70 3.0D SE
Re: Parking brake failure
Post by X5Sport » Wed Jun 24, 2015 9:32 pm
Sticky cables, or actuator unit, worn shoes.  Could be any of them.
pcdee
Post by pcdee » Thu Jun 25, 2015 9:55 am
Okay.... I'll start with warn shoes and check brake fluid, then move on
X5 E70 3.0D SE
Lamby
Post by Lamby » Sun Mar 27, 2016 10:22 am
Same problem here.  Did you have any luck sorting it?
pcdee
Post by pcdee » Sun Mar 27, 2016 9:34 pm
[quote="Lamby"]
BMW job in the end.....needed a new actuator.  The gears has broken, they are plastic!
X5 E70 3.0D SE
kjb1
Post by kjb1 » Mon Mar 28, 2016 8:14 am
how much?? the part was £800 ish on its own if I remember correctly
Sent from my iPhone
pcdee
Post by pcdee » Thu Mar 31, 2016 6:53 am
[quote="kjb1"]
Sent from my iPhone
Just shy of 1k
X5 E70 3.0D SE
Post by X5Sport » Thu Mar 31, 2016 5:12 pm
:rant: :crazy1: :cry1:
