2002 (52 plate) park light warning
darisaac
Post by darisaac » Sun Apr 12, 2015 11:09 am
Is there a "how to" on how to replace the park light (I assume it's the same as the side light) bulb?
I've located the bulb and can take it from the light casing but can't work out how to remove it from the holder  O:-).
Picture of the bulb and holder attached, any help is much appreciated.ImageImage
X5-D-Sport
Re: 2002 (52 plate) park light warning
Post by X5-D-Sport » Sun Apr 12, 2015 11:32 am
Not sure what you mean by "park-light" ?
Looks like a front fog light bulb...
The bulb is part of the connector casing & comes as one chunk....
It does not seperate from the electricsl connector casing.
darisaac
Post by darisaac » Sun Apr 12, 2015 11:56 am
The warning on the dash says to check the park light, the bulb that seems to be out is the side light, ie not the headlight but the one beside it. If the bulb is connected as one, I need to replace the whole thing?
X5-D-Sport
Post by X5-D-Sport » Sun Apr 12, 2015 12:50 pm
Yup....
The whole bulb & plastic fitting... it is a single item & will not dismantle.
When you fit the replacement, ensure you DO NOT touch the bulb.. as the bulb will fail quickly.
Also, clean the sealing surface that the orange O-ring  contacts, & possibly apply a smear of oil.....
.(robbed from the dipstick on your finger).... to ensure a good waterproof seal.
This bulb has no rear protection other than its fitting, to simplify the lamp unit & manufacturing costs etc
darisaac
Post by darisaac » Sun Apr 12, 2015 9:41 pm
thanks any idea where to buy these reasonably?
Post by X5Sport » Sun Apr 12, 2015 9:46 pm
Side/Park light is the same thing.  We call it a 'side' light but the U.S. call it a 'park' light.  Too much effort to recode the warning for the UK... ;)
X5-D-Sport
Post by X5-D-Sport » Sun Apr 12, 2015 11:17 pm
Get these from Halfords or better still/cheaper at any motorists discount centre.
