For the second time now, my battery has completely discharged. What I find strange is the car can be left for a week quite regularly and then it starts up with no sign of weakness, yet the problem arises when i've driven to work, it is left all day, and when I return to the car it is completely dead.
Could this be the alternator?
I did notice that my DRL was switched on by accident, but I doubt this would cause an issue as I believe the car goes in to sleep mode after a short time of inactivity?
I have found various information on here regarding discharging batteries, and there are several causes, however based on the information i've provided I am hoping someone can shed some light on this.
Thanks in advance.
Battery discharging
- kjb1
Re: Battery discharging
check the terminal for your jump start under the hood. Positive terminal, ensure it is fully tight!!!
Sent from my iPhone
Sent from my iPhone
- kjb1
use a spanner, not just A hand tight check etc.
Sent from my iPhone
Sent from my iPhone
Thanks kjb1,
The local garage have sorted it.
Turned out to be a loose earth connection !
- kjb1
[emoji106][emoji106][emoji106][emoji106]
Sent from my iPhone
Sent from my iPhone
