"door open" message
Nick73
"door open" message
Post by Nick73 » Mon Jan 26, 2015 8:31 pm
Hi all
So Ive been having intermittent alarms that I thought was related to the cold weather, but I've also had the internal light failing to go out, and oin the last 2 days this is also including a "door open" message when driving.  I've managed to figure out which door using the BMW Scanner 1.4 (ZKE module shows driver door error)
New latch assembly ordered so in the short term I have one remaining problem of not being able to lock the car.
Does anyone know if i untick the the DWA check box in the ZKE module will that dissable the alarm for the time being ,but let me re-set it later on?
cheers
Nick
Smeeagain
Re: "door open" message
Post by Smeeagain » Mon Jan 26, 2015 10:05 pm
If I remember correctly double clicking the lock button disables the alarm
Can you lock the door manually with the key?
Smee
Post by X5Sport » Mon Jan 26, 2015 10:08 pm
Disables the interior sensor, but not the doors.
Smeeagain
Post by Smeeagain » Mon Jan 26, 2015 10:30 pm
pk, thanks. Coming at it another way then, does locking the door manually simply lock the door and not activate the alarm?
Smee
Steamyrotter
Post by Steamyrotter » Mon Jan 26, 2015 10:43 pm
I think you are correct.
In opposition if you lock with the fob and open with the key the bloody alarm will not shut up easily....  Tested that a few times!!!!
Nick73
Post by Nick73 » Tue Jan 27, 2015 5:05 pm
Thanks guy, yes I can lock it manually (close driver door, open rear passenger door and reach in to lock driver door and passenger door).
Bit of a kerfuffle but works for now, but you have to "lock" it with the key fob before you can unlock it.
My only concern is that without being locked properly I don't think it goes into a proper 'sleep' mode so the battery draw is higher than it should be.  Ive manually turned the interior lights off which has helped.  But I have a horrible feeling that if you lock the doors manually, and the battery goes completely flat, then there is no way to get back into the car!
Roll on the bloomin delivery!
cheers guys
Nick
Smeeagain
Post by Smeeagain » Tue Jan 27, 2015 11:41 pm
so maybe leave the bonnet on the latch so you can access the battery charging points if needed?
