anyone had this issue (2004 E53 3.0 D Auto
Smeeagain
Post by Smeeagain » Wed Jan 07, 2015 4:09 pm
ok this is anew on one me and not seen anyone reporting similar as far as I can recall.
When I turn the steering wheel I get a  squeaking sound. Really irritating. Worse when turning the vehicle to the left than the right. Sound like something is rubbing. Any ideas what could be causing this and what to lubricate ?
I've tried adjusting steering wheel position which improves it slightly but it not the wheel position that I want
Smee
Imy
Re: anyone had this issue (2004 E53 3.0 D Auto
Post by Imy » Wed Jan 07, 2015 4:18 pm
Power steering fluid?
Smeeagain
Post by Smeeagain » Wed Jan 07, 2015 5:33 pm
what makes you say that?
jason1872
Post by jason1872 » Wed Jan 07, 2015 5:51 pm
i had similar and turned out to be the track control arm,ball joint making the noise.
Smeeagain
Post by Smeeagain » Wed Jan 07, 2015 6:18 pm
because it was knackered or does it make the noise because it needs lubricated (if it can be)?
jason1872
Post by jason1872 » Wed Jan 07, 2015 6:23 pm
it wasn't knocking or anything,just kinda squeak or rubbing like noise when i turned the wheel,i cut a small hole in the rubber boot that covers the ball joint and put some engine oil in it,result no noise so changed the whole arm.
TimX5
Post by TimX5 » Wed Jan 07, 2015 8:39 pm
[quote="Smeeagain"]
Smee
Mine does the same very faintly,  turn on the wireless and you can't hear it , think it's probably the contacts between the steering wheel and the column.
shadrack
Post by shadrack » Wed Jan 07, 2015 8:53 pm
[quote="TimX5"]
[quote="Smeeagain"]
Smee
wireless...........how old :))
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
TimX5
Post by TimX5 » Wed Jan 07, 2015 9:34 pm
[quote="shadrack"]
[quote="TimX5"]
[quote="Smeeagain"]
Smee
I knew it would make someone  chuckle lol , a wireless is more reliable than a x5  :))
Smeeagain
Post by Smeeagain » Thu Jan 08, 2015 7:07 pm
Wireless is new - I prefer to switch on the radiogram  :D
Post by X5Sport » Fri Jan 09, 2015 8:58 am
.......and wait 10 minutes for the valves to warm up.  That's why cars didn't have heater, the wireless did it all.
Ah, the days of 'The Light Programme'......... :P
Steamyrotter
Post by Steamyrotter » Fri Jan 09, 2015 1:16 pm
Will you lot get a room...
Or is it the whole wing in the retirement lodge????
>:D
Post by X5Sport » Fri Jan 09, 2015 1:58 pm
Bog off or I'll hit you with my walking stick.......after I've got my Zimmer out of the car.... >:D
Steamyrotter
Post by Steamyrotter » Fri Jan 09, 2015 8:30 pm
You'll have to catch me first..
These mobility scooters can shift when they least want to...
