Morning. ..
I put the beast in reverse and looked at the off side mirror and it failed dip.
I tried to adjust it manually and no luck, it would move left to right just not up and down. Driver side is fine manually.
Dipped wing mirror
pcdee
Dipped wing mirror
X5 E70 3.0D SE
The Mechanic
Re: Dipped wing mirror
The nearside mirror only dips in reverse if you have the selector set to the offside mirror. This doesn't explain why you can't move it manually though.
Never knowingly underfed
2012 E70 30d M Sport
- Yaz40D
Having the same problem on my 10 e70. Any fix to this???
2010 X5 xdrive40d in Bronze
splang
I had this and needed a new motor unit
SCOOBYR1
I have the very same issue, it's not a major PITA but it is a feature I found very useful to save kerbing my wheels. I have stripped the mirror apart using a "How to guide" just to see what was involved. An entire mirror replacement is exceptionally expensive, so that's a non starter
My driver side mirror is fully functioning so I was contemplating stripping that down to rob and swap the operational motor in the driver side to the inoperative one on the passenger side, which I have read is a straight swap. I'll let you know how I get on. :xmaswink:
- briankerrys47
Parts available on eBay,cogs splindles etc
Nine468
[quote="SCOOBYR1"]
Can you show us the link to the "how to guide", as this is a job im in need of doing on my car also...
It seems to be getting a common fault..
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
- goose
[quote="Nine468"]
[quote="SCOOBYR1"]
9 times out of 10, the NS reversing mirror doesnt dip as the left/right elec mirror switch on the drivers side door handle has been knocked into the wrong position.
I have done this many times, and always shout and swear thinking its broken when it isnt!!
goose
[quote="SCOOBYR1"]
goose
_______
2008 X5 3.0sd M Sport - Carbon Black - Evolution remap
1972 VW Karmann Ghia Coupe - Sunburst Yellow
