Oil consumption
kamb
Oil consumption
I have covered approx 5000miles since last oil change upon checking dipstick level today it was on minimum level
I know they burn oil more than other cars but is this normal?
No oil leaks seen only bit of smoke at start up which everyone says is normal check other posts
Raj
- Lifer
kamb
Re: Oil consumption
It's 3.0d
- CondorX5
Re: Oil consumption
BMW dealer recently advised me that adding 1l oil every 600 miles is normal - I have a 4.8 though, they do use oil.
X5 2005 Le Mans Blue 4.8is
Re: Oil consumption
That sounds normal for the 3.0d. Well within the BMW spec. These engines do use a bit, and mine (218bhp variant) certainly did.
TimX5
Re: Oil consumption
My 06 3:0d used 1ltr of oil after covering 1650 miles on holiday touring with a 6 birth caravan , I was abit concerned also but after reading up on the forum it seems quite normal.
kamb
Re: Oil consumption
Cheers it took just over 2l to get to max on dipstick so
Sounds about right
Good job I stocked up on oil whilst it was cheap at eurocarparts few months back
Sounds about right
- kkx5
Re: Oil consumption
[quote="CondorX5"]
1L every 600miles is normal?? 10L every 6000miles...Tell them they are nuts...N62 dont use oil. Valve seals are gone on yours.
Raj
- Lifer
Re: Oil consumption
[quote="kkx5"]
[quote="CondorX5"]
Might be worth checking if it wasn't just a typo before going off on one as per normal.
[quote="CondorX5"]
Raj
- Lifer
Smeeagain
Re: Oil consumption
[quote="kkx5"]
[quote="CondorX5"]
I think you're wrong - I would say its reasonably normal. Most folk don't bother to check oil levels these days and simply expect it to last between services. Also depends on your style of driving of course
[quote="CondorX5"]
- kkx5
Re: Oil consumption
It's not normal for n62. I've noticed some of You on this forum don't have a clue about engines, yet they claiming, I'm wrong >:( .You dont have to top oil up between services.
Raj
- Lifer
Re: Oil consumption
[quote="kkx5"]
Tbh I think it's wrong to say that you should never need to top up oil between services. Every engine will burn some oil so I can't see how it can go 15k miles for example without topping up. I agree every 600 miles is excessive though hence thinking it was a typo possibly.
- kkx5
Re: Oil consumption
What kind of driver is changing oil every 15k? 10k is max. 1l per 10k is normal.
Re: Oil consumption
[quote="kkx5"]
Those with Condition Based Servicing.......up to 20k! I've had several cars, and not just BMWs, with CBS and the change interval varied with driving style. Only if the WRONG oil was used did it drop to 10k intervals.
