Tyre Advice
dobbor1
Tyre Advice
I currently have the same tyres on all 4 corners and now need the rears changing. I have the 315 20 inch rears. I cannot find another set of the same tyres to match the new fronts just replaced. Will I be ok changing to another make and tread pattern on the back and will it upset the car?
Jeff
Sent from my HTC One using Tapatalk 2
Jeff
Currently: 2011 E70 X5 40D M Sport Black Sapphire
Previously: 2006 E53 X5 30D Le Mans Blue Sport Edition
Re: Tyre Advice
It's likely to be one of those 'suck it and see' scenarios. It might have no adverse effects at all, but then again it might.
The rolling diameter is the bit to watch. Some X5s seem to get unhappy if the difference in wear is significant whereas others don't seem bothered. There have been a few recent threads on this after diffs began breaking along with transfer boxes.
I only use the BMW approved rubber now. It may cost a bit more but it's cheaper than a smashed transmission!
I also believe these cars should be a lot less fragile and tolerant of different tyres than they are!! >:(
Never anthropomorphise computers. They hate that.- Sanj
- Lifer
Re: Tyre Advice
Correct 20's size are:
Rear 315/35/20
Front 275/40/20
Try to stick to them - Toyo are good too (if you can find them). I've had them on mine for a number of years without issue.
Rear 315/35/20
Front 275/40/20
dobbor1
Re: Tyre Advice
I might have to bite the bullet and change all 4 for piece of mind. Then sell the fronts as they are like new. Can you send me links for the Toyos please and I assume the tread pattern front and back are the same?
Anyone fancy front Yokohama Advan ST's?
Jeff
Jeff
AW8
- Lifer
Re: Tyre Advice
4x4tyres.co.uk site indicates they have some advan st in limited stock for rear - just watch out for aggressive cookies on your computer if you go on their site
TimX5
Re: Tyre Advice
What make are the front tyres , my mate buys and sells tyres for a living so I could ask him if he can get some to match
dobbor1
Re: Tyre Advice
They are Yokohama Advan ST 275/40/20 110Y.
I'll check out the site above Thanks.
TimX5
Re: Tyre Advice
[quote="dobbor1"]
I'll ask him tomorrow and let you know the outcome.
Tim
Tim
dobbor1
Re: Tyre Advice
I have now contacted over 6 suppliers including the ones advertising stock online and none of them have stock. Yokohama UK do not even know when they will receive a delivery. So plan B is 4 new tyres.
Right chaps, all recommendations greatfully receieved please. Not run flats.
Jeff
Jeff
Re: Tyre Advice
Michelin Latitude Sport 3 seem to be going down well. New version apparently and not sure on sizes or prices.
mark hamster 28
Re: Tyre Advice
when I purchased my X5 BMW approved, it had 4 new tyres on and they are bridgestones on the front and dunlops on the rear all run flats and I have had no issues so far ::) but now reading this post, should I expect a problem O:-)
::) X5 M Sport F15 3.0D M Sport ::)
PREV-
New Model X1 Xline 2.0 D 2015
X 5 M Sport 3.0 D (E70) Only been gone 2 days but missed
Ford Focus ST3
Audi A4 Cab Final Edition
Range Rover Sport HSE
PREV-
Ford Focus ST3
- kkx5
Re: Tyre Advice
Its been many times on this forum. E53 its not design to be on run flats... Latest Michelin not rft is the way to go. Bridgestons are good too but quite stiff. Pirelli great but will last max 7k on x5. I had coopers 4xs, very good traction, wet performance etc.
dobbor1
Re: Tyre Advice
I am gutted about the Yokos because I put them on at 69k and I am now on 103k with a little tread to go. They have been amazing lasting this long. Only just changed the fronts 2k ago.
Like the look of the Vredestein SUV Sessantas. Cool looking tread pattern too.
- CondorX5
Re: Tyre Advice
Have used Sessantas on mine for several years now - good wear, good looks and good road holding. I change them over the winters around November -Vredestein Wintracs.
X5 2005 Le Mans Blue 4.8is
Re: Tyre Advice
There is no problem with running an E53 on runflats. The ride may be much firmer, but other than that it's fine for both safety and mechanically. And that's straight from BMW themselves because I had them on mine and would not have done if there had been any doubt. You must have a TPMS system on the vehicle though. I did.
Non RFT tyres will last a lot longer though. Nearly double in many cases. I'm looking to replace the Dunlop SP Sportmaxx on my X6 but will stick with RFT for that one as it's under BMW Warranty and the X6 seems to be better with RFT than the E70 for some reason.
